did i hit fuel cut????????
Old Feb 7, 2006 | 02:16 PM
EvoDan2004's Avatar
Originally Posted by taenaive
I think shiv knows the detail but I will tell you from what I heard and experience.
fuel cut happens when you suck in the dense air too much for certain period of the time. So, your MAF sensor reading will be very high. When your ECU sees this spike, it will cut off the fuel. It can also happen when your engine knocks like crazy or fuel pump fails...etc.
i dont have a spike. as for the rest i dont no. thanks
Old Feb 7, 2006 | 04:16 PM
4-BNGR's Avatar
list your mods...
Old Feb 7, 2006 | 07:53 PM
EvoDan2004's Avatar
anyone???
Old Feb 7, 2006 | 08:32 PM
EvoDan2004's Avatar
no one has any more idea's?
Old Feb 8, 2006 | 06:25 PM
EvoDan2004's Avatar
anyone.
Old Feb 8, 2006 | 06:30 PM
SOUTHSIDEITALIA's Avatar
Originally Posted by 4-BNGR
you hit "fat" cut. too much weight in the car
Awesome!
Old Feb 8, 2006 | 06:33 PM
EvoDan2004's Avatar
Originally Posted by SOUTHSIDEITALIA
Awesome!
its not funny but it really is funny. lmao but im not. ??????????????????
Old Feb 8, 2006 | 06:39 PM
AJsGenerX's Avatar
Your motor probably misfired. Replace all your plugs with NGK BPR8ES plugs. Its around that time to swap plugs anyways. When your car misfires, you'll feel a buck and lose power instantly. You basically run on 3 cylinders if one cylinder misfired. Sometimes it may lose power, buck, and then suddenly come back to life as the cylinder sparks up again. Misfiring is generally a problem with the spark plugs and wires. Definitely check your plugs and wires. A misfire feels like youre hitting fuel cut.
Old Feb 8, 2006 | 06:54 PM
Fut cut, funny, but true, but I have only experienced that one when tuned very aggresively, or when flooring it at high RPM....... took a while to get of the flash feeling That is knockinh however, flashing CEL......do you have any light come on at all? Doesn't sound like it, and a misfire would definately give the po300 code?
Old Feb 8, 2006 | 06:56 PM
EvoDan2004's Avatar
i have no codes nor a check engine light.
Old Feb 8, 2006 | 07:00 PM
4WS Tuning's Avatar
turn ur boost down to 18 for a couple days and see if it does it again...in fl i have to constantly mess with my mbc cause at night its in the 50's and during the day is in the 80's ill boost 20/21 during the day and at night itll be 23/24....thats what was causing my car to do the same thing
cheers
Old Feb 8, 2006 | 07:01 PM
Check your plugs, and get back to us. 22+, run 8 heat range, i use NGK, but the stock plugs should last longer than that on low mods? What are they?
Old Feb 8, 2006 | 07:04 PM
EvoDan2004's Avatar
mods are. tbe, no cat, mbc, fmic, icp, hks intake, aps bov, boosting at 20psi.
Old Feb 8, 2006 | 08:34 PM
have you checked for boost leaks. Your gauge may be reading wrong, and you are overboosting, but usually a CEL, with overboost. But possibly, your plug/s are fouled. Easily fixable.
Old Feb 9, 2006 | 07:27 AM
AlwaysinBoost's Avatar
that doesn't sound like fuel cut to me. WHen you hit fuel cut you will know, its like hitting a brick wall.
what your describing seems more like just breaking up from running too rich up top. I had the same problem with simular mods, get an SAFC or a tune and you'll be all set.
it prolly wouldn't hurt to check your plugs though if they have 30k miles on them.
