did i hit fuel cut????????
it never happend befor till tonight. i had 4 people in the car going about 60mph. droped to 4th gear and the car took off then bucked then took off again. it only happened 1 time. what could this be. it never happens when im by my self. thanks
Originally Posted by anthonypazsd
What RPMs were you at? Do you have a boost controller? If it bucked really hard, maybe you hit boost cut off. RPM fuel cut will only make a horrible noise, not give you a huge buck.
Sounds like you hit boost cut. My car bucked super bad when I spike 25 PSI with my MBC. Having multiple people in your car shouldn't be a factor, its just embarrasing. What brand MBC?
Weird. I have an UNOS and was having all sort of spiking issues in the beginning. So with your friends in the car, you droped to fourth, going about 60, and you are positive you were looking at your boost gauge and saw it hit 20 and no higher? It really sounds like you hit boost cut, and that jerky sensation is what occurs at 24,25,26.
UPDATE
today it did it when i was by my self. in 3,4,and 5. no spiking or nothing. so i did some tests. i turned the mbc down 2 clicks. im still boosting at 20 psi but now it dont do what it was. the car pulls like a rocket till redline in all gears. can anyone help me understand this.
Originally Posted by evodan2004
im positive. it hit 20psi and the car took off then bucked then took off again till i changed gears and then it did it again.
UPDATE
UPDATE
fuel cut happens when you suck in the dense air too much for certain period of the time. So, your MAF sensor reading will be very high. When your ECU sees this spike, it will cut off the fuel. It can also happen when your engine knocks like crazy or fuel pump fails...etc.
