high exhaust temp
high exhaust temp
hey im running a ralliart sport comp ecu and now my old stock ecu is wasted from sitting in a damp basement or from being knocked around but ive got an egt and ive noticed the eshaust temp gradually getting higher and higher just at idle its betweeen 1000 and 1100 this doesnt seem normal and i noticed at full boost which is about 20 psi it can get all the way up to 1900 when i first started running this ecu it ran about up to 1600
any help on lowering the temp?
if your temp is goign up, it means your car is running leaner or u have to chck if your gauge is accurate, i would get a wide band or go on a dyno to check the air fuel ratio on your car.
On my 05 EVO 8 EGT @ 22psi would never go above 1400*C
Originally Posted by mchuang
It can also mean you have too little timing also if it increases, best thing to do is find a way to get it tuned
it s the total opposite, more timing will cause the car to run leaner, and increase exhaust temp
Originally Posted by GTKage
uh how does less timing increase exhaust temp?
it s the total opposite, more timing will cause the car to run leaner, and increase exhaust tempDave
also should the exhaust temp keep rising as i get higher up the rpms or should it peak off at some point and stay. going down the high way i topped the car out at 155 and glanced over at the temp as i was going through the rpm it kept rising and never stopped it eventually buried the needle in the autometer gauge goes to 1800 i think
Originally Posted by djh
And guess what, the reason lean mixtures tend to have higher EGTs is that they burn slower. See how that works?
Dave
Dave
When people say that lean mixtures burn slower, they usually mean leaner than 14.7:1.
If you run too rich or if the timing is really off (or a combination of both) flames could be reaching into your exhaust past the exhaust valves, hence the high EGT. Buy a wideband.
