INSTALLED 264's?& IDLES LIKE 280!?? & GETTING FUEL CUT!??WTF?
Old Feb 18, 2006 | 12:17 AM
nrcooled's Avatar
Have you been tuned by Al?
Someone correct me if I am wrong but, Al's flash removes the fuel cut so you shouldn't be hitting it if you are flashed.
Old Feb 18, 2006 | 12:45 AM
yellowgsr's Avatar
I will be in two weeks
Old Feb 18, 2006 | 09:22 AM
yellowgsr's Avatar
bump
Old Feb 18, 2006 | 10:30 AM
PeakBoost's Avatar
Originally Posted by LuxuryBroker
make sure you are not one tooth off ....
set to tdc, pull off the cam gear cover and the cam gears for tdc (marked on valve cover).
the marks will almost look like they are facing a bit away from each other.
HTH
fuzzychi
Jul 24, 2010 06:13 PM
bogey8
Jun 23, 2006 04:52 PM
j8
15
Apr 2, 2005 01:41 PM
IS2000
Jul 19, 2004 11:08 PM
EVO8 WHOA
32
Oct 11, 2003 09:42 PM
