Oil cleaner ruined oil pump?
Old Feb 22, 2006 | 07:14 AM
TampaTurbo's Avatar
Originally Posted by mchuang
This is more than likely the problem.. you added more boost untuned, detonation killed the bearings.
I hope thats the case. I would hate to move forward on this oil cleaner.
Old Feb 22, 2006 | 07:16 AM
mchuang's Avatar
Well once you pull the head you will definetly find out because detonation will show on the pistons and alot of times on the plugs.
Old Feb 22, 2006 | 07:21 AM
TampaTurbo's Avatar
Funny thing is the knock indicator didnt light up.
Old Feb 22, 2006 | 07:35 AM
modvp's Avatar
was there enough oil in there following your oil change?
Old Feb 22, 2006 | 07:40 AM
TampaTurbo's Avatar
There was when I left. It was at the top notch mark. I'll check to make sure my oil filter is on securely.
