What's with Buschur Racing's dyno....with dyno sheet of RS.
Nice work David. Seems the 20g wheel was worth a good 40whp after all. Good news for dsm guys. The 20g wheel has been revised. Just recieved a 20g from japan this week. My eyes popped out of my head looking at the wheel. The new wheel has the same features of the evo16g. Small lightweight hub, resulting in larger blades.
Here are some pics, garrett 60trim, old 20g (60trim), new 20g, evo16g. The blades on the new 20g are virtually the same size as the garrett blades. The garrett just has a huge hub. there is a guy on dsm tuners rockin a 20g. He has run 11.0 at 127mph with 2900lbs race weight. That takes about 464 whp. He has recently changed to the 20g/td06h hotside and feels the time will tumble when the track opens in march.
http://photobucket.com/albums/f397/l.../?sc=1&multi=3
I bought the td06h/20g for my 2.3 that I am dropping in my evo1. Should be fun.
I don't think a 2.3 will make 500 ft lbs. I just finished tuning a 2.3 liter with this turbo on it on a mild tune and nowhere near the mods I have it made about the same power as my car did before I put the Revolvers in.
Yes, I am definetely staying with the Revolver cams! Spool up is close to the same as before.
Our dyno when tested back to back against Tym's AWD Dynojet measure 22% less than his dyno did. Going from our numbers to his we'd have to add 33%. I was very close to driving to his shop today to dyno the car there. I ran out of time.
The car was a beast on the street though.
Not sure what a 340 whp car will run off our dyno. Like Trevor said, his friend went 122+ trap speeds with that power. My RS is lighter than most EVO's and with 330 whp ran a bunch of 120-124 mph trap speeds.
David Buschur
www.buschurracing.com
David Buschur
94awd,
I thought you didn't like the 20G? Maybe I have you confused with someone else? If not glad you came around
I ran 11.05 at 127 mph way back with my AWD Talon that John Shepherd has now, on the 20G-TD05H. I never liked the TD06 version of the 20G. When I sold the car to John his superior driving took the exact same combination to 10.72 at 131 mph.
I am thinking/hoping, my RS is going to run into the 10's at 130 mph the way it sits right now. I am keeping it like it is and will run it in the Stock Appearing classes at our Shootouts we hold here.
Trent, our welder/friend at the shop, has the 20G on his car but with a semi-mild build. He drove my car today. He was hot and heavy for a GT35R. He turned to me and said, "I think I want to build my car exactly like this one."
What a blast to drive. Instant spool up, 450 ft lbs of torque at 3800 rpm. Nice.
David Buschur
David Buschur
I posted a question about this on your forum a few days ago here.
I don't think a 2.3 will make 500 ft lbs. I just finished tuning a 2.3 liter with this turbo on it on a mild tune and nowhere near the mods I have it made about the same power as my car did before I put the Revolvers in . . . .
On your car you are getting peak TQ at around 3800, so where does it hit on the 2.3? Did you post up a thread about this? Thanks!
EVOlutionary
Originally Posted by EVO Nathan
The only reason that I am asking is, I dont think we have yet to see a good result from this turbo on full bolt on Evo 03-05 on pump. If there is a good result that I simply missed somewhere, please let me know so I can read up on it.
Thanks,
Nathan
Thanks,
Nathan
In turbocharging, you aren't going to see a big increase in power at the same boost level just from changing the compressor wheel unless you are already past the flow limitations of the wheel you are switching from. Simply put, if you aren't making around 400whp on pump gas, you're not going to see a big jump on pump from just putitng on the larger sompressor wheel. On c16 or alky, the ceiling will be raised to round 450whp (maybe more as I havn't searched around for many dynos) with the larger wheel.
I am still looking around for dyno sheets that show 300awhp on Dave's dyno with full bolt on's and this Evo 8 20g-9 on 93 octance.
Now, back on topic. Dave I am really looking forward in seeing some of your track runs. Hurry up and get that thing going.
The 2.3 liter did not make the car surge anymore. It made 20 psi at 3,000 rpm.
David Buschur
David Buschur
I changed the rules for the DSM and the EVO. The classes will allow a tubular 02 housing but NO external dump tubes. No headers. Stock appearing turbo.
David Buschur
David Buschur
David Buschur
David Buschur
On my stock bottom end 2.0L, stock '04 turbo I hit full boost at about 2900rpms in 5th gear. Third gear is quite a bit higher due to less load of course.
EVOlutionary
