boost question
Old Feb 22, 2006 | 06:03 PM
Warrtalon's Avatar
Originally Posted by evouser12
speaking of boost...i get my ecu back toorrow and told Al that i will be running 21 PSI...does that mean i set my PSI to about 23-24 to spike and then tapers to 21..or do i spike it at 21??
Grr, I just answered that, haha. Set it to spike around 21-22psi in 3rd gear at peak boost. It should taper down to 19 or so after redline...
Old Feb 22, 2006 | 06:05 PM
DarkEvo's Avatar
I wrote to dynoflash with no response so maybe someone on here can tell me...when you get the dynoflash mail-in flash and you have nothing done to your car but a drop in K&N is there any point of getting a boost controller or is the reflash setting the boost high enough?
Old Feb 22, 2006 | 06:09 PM
evouser12's Avatar
thanx warrtalon again for the 100th time haha
Old Feb 22, 2006 | 06:11 PM
evouser12's Avatar
and i dont have my new JDM MR DV on yet..and i get my ecu back tomorrow...me settin my boost with my stock bov isnt gonna change nethin when i put my new bov on, right
Old Feb 22, 2006 | 07:00 PM
broddey's Avatar
JDM MR DV? How much boost can it hold? I have US Spec MR, but how much does the JDM Cost?
Old Feb 22, 2006 | 07:09 PM
sivs's Avatar
hey stupid question if you blow into the vaccuum NIPPLE on your BOV and hear air is that bad?
Old Feb 22, 2006 | 07:23 PM
Warrtalon's Avatar
Holy crap, these last 3 posts scare me.
Sivs: wtf, I have no idea.
Broddey: you have a IX, so you already have the JDM MR DV, which holds 24-25psi easily.
Evouser: it won't make a difference. You'll be fine on the stocker and fine when adding the MR DV.
DarkEvo: on your 04, you'll be fine without an MBC until you add later mods.
Old Feb 22, 2006 | 07:44 PM
sivs's Avatar
warrtalon What I mean is I bot my GFB BOV out of my car now and when I blow into the vac nipple it doesnt hold PSI my understanding is the intercooling inlet(pressurised side) and the manifold/vac nipple of the bov when boosting cancel themselves out 2 keep the spring shut. I f 1 were 2 leak the cancelling effect would not be as great. it sounds like the seal on my BOV 4 my sring tension is worn or broken. CAPRENDA
Old Feb 22, 2006 | 08:05 PM
Evo_Jay's Avatar
edit
Old Feb 23, 2006 | 02:10 AM
Silvercar's Avatar
i KNOW ITS SOME WHERE ON HERE BUT IM LOOKING FOR A BAR TO PSI CONVERTION CHART CAN SOMEONE HELP ME FIND IT?
Old Feb 23, 2006 | 07:00 AM
Warrtalon's Avatar
Please turn off your CAPS LOCK:
World Wide Metric
Old Feb 24, 2006 | 03:29 AM
Silvercar's Avatar
World Wide Metric
THANK YOU very much.
