I want to blow up my engine!!! (Edited)
Old Feb 21, 2006 | 09:13 AM
FlipRyder21's Avatar
Wow thanx for the post manngggg.... mind if I ask you. Who flashed your Evo?
Old Feb 21, 2006 | 09:19 AM
nrcooled's Avatar
I would rather not say to prevent this from turning into vendor fanboi war.
Old Feb 21, 2006 | 09:23 AM
PureEvo's Avatar
How much boost where you running? Atleast your getting to put a stroker in (the bright side)
Old Feb 21, 2006 | 09:31 AM
Eclipsed Evo's Avatar
Originally Posted by Derek888
thats why I have a custom tune....
+1
Old Feb 21, 2006 | 09:33 AM
Az3ar's Avatar
very good post
Thats why I am keeping her stock
0 to 60 in 4.5sec and QM in just under 13 sec is very nice... no need for more.
she is quite and very soft and i like them like that.
Old Feb 21, 2006 | 09:35 AM
ZK's Avatar
ZK
i totally agree on the internet. everyone will jump in and say something but very few will know what is truly good for you or your car.
plus it is very hard to diagnose a problem over the internet. you kinda have to be there to know what is going on.
the best thing for reliability - LEAVE IT STOCK!
Old Feb 21, 2006 | 09:38 AM
Maximum Boost's Avatar
+1 custom tune is the only way to go.
Old Feb 21, 2006 | 09:42 AM
S2Kstephen's Avatar
while your at it do it... they are not that expensive anyways.
Already got the cams in...should have done it all at once!
Old Feb 21, 2006 | 09:50 AM
blitz118's Avatar
Why is putting in 2600lb pressure plate not a good idea? What brand pressure plate were you running? Did the flash cause your engine failure? Why didn't you have the necessary gauges to monitor your car?
Old Feb 21, 2006 | 09:52 AM
SterlingEvo's Avatar
great post bakari. People tell me I have too many gauges, but I HAVE to see what's going on with my car every second! I hit something in the road a couple of weeks ago and it actually slashed my oil filter open, which I of course didn't realize. Normally I'd have driven a bit thinking "I hope nothing bad happened" but I noticed my oil pressure gauge shot down to zero. This happened BEFORE my stock oil light came on. I immediately stopped, got the car towed, set back up and it seems to be running just fine. Had I not been monitoring, the problem could have been significantly worse!
Old Feb 21, 2006 | 09:59 AM
R3dline's Avatar
+1
Old Feb 21, 2006 | 10:18 AM
note: sometimes people refer to custom tunes as "flash" still... it doesn't always mean "mail-in" or preset map. In general people are talking about any change to the stock ECU, whether mail-in or in-person custom as a "flash" as opposed to piggyback or standalone...
Old Feb 21, 2006 | 10:22 AM
nrcooled's Avatar
I was running 21psi like a lot of guys on the boards here. It's just that my setup, for whatever reason, didn't work well. Had I been monitoring the car though I would have seen that my AFRs were off, or my oil pressure was low (or too high), or that I was picking up knock.
Old Feb 21, 2006 | 10:27 AM
nrcooled's Avatar
I also had a "custom" flash tuned ECU.
Again, I will state that flashes are great but you as the user/custormer must ensure that the flash is working as intended for your setup. Monitor everthing!!!
Old Feb 21, 2006 | 10:33 AM
staatz's Avatar
Sorry to hear about the car..I will have to get some more gauges for extra safety. Hope everything turns out alright.
