35R Installed Need Help!
Old Feb 23, 2006 | 09:34 AM
denolloyd's Avatar
I recently installed the following in my Evo 8:
RNR 35R Kit
Front Mount
Fuel Pump
Alky kit
Greddy type s
AEM Wideband Guage
Oil Pressue Guage
Boos Guage
I still have 880 injectors, HKS 280's, etc to install, however, the car will not idle. It is running extremly rich. There are no boost leaks. I plan to flash the ECU, however, could tuning be an issue at this point? The BOV is VTA, however, the idle issue is not happening during or after boost. THis is upon start up. I dont think the parts installed thus far would prevent the car from ideling. Could it potentially be the fuel pump?
Any assitance would be greatly appreciated.
Thanks!
Old Feb 23, 2006 | 09:44 AM
WrX Kila's Avatar
Hmm, and this started happening after the install?
Old Feb 23, 2006 | 10:10 AM
denolloyd's Avatar
Yes. The idle issue came after the install. Before the 35r kit was intalled i had a profec b, 3"TBE, and a cone filter. The car idled perfect.
Old Feb 23, 2006 | 10:26 AM
schafer's Avatar
im thinking tuning would help just a little....
Old Feb 23, 2006 | 10:32 AM
deadbeatrec's Avatar
the VTA bov could be causing idleing problems. the only thing that i can see causing it.
Old Feb 23, 2006 | 10:35 AM
justchil's Avatar
How did you prime the turbo? How long are you letting it idle for?
SilverEvo8owner's Avatar
do you have any time of engine management at all?
If you dont, theres your problem with just the injectors alone
Take your 880's off and put the stock ones back for now until you have it flashed
stay out of boost too
Old Feb 23, 2006 | 10:41 AM
VIIImylunch's Avatar
is it good to run a 35R w/ a flash?
Old Feb 23, 2006 | 10:44 AM
Jasil's Avatar
Go to a premier tuner and you're ordeal will be fixed.
Old Feb 23, 2006 | 11:00 AM
jj_008's Avatar
You need a reflash to scale your injectors. Without a reflash it will barely run.
Old Feb 23, 2006 | 11:19 AM
denolloyd's Avatar
Thanks for the responses.
The injectors have not been installed as yet... Would the VTA BOV cause an issue even if the car has not gone into boost? Im just trying to let it idle... Not drive.
Thank again!
Old Feb 23, 2006 | 11:25 AM
ok guys the injectors are not in yet as stated above. its the vta bov. put the stock diverter valve that recirculates back in and see what happens.
Thank again!
Old Feb 23, 2006 | 11:42 AM
denolloyd's Avatar
Will do...
Sharkbite2000's Avatar
You need a flash and a tune thats it.
Old Feb 23, 2006 | 11:43 AM
the type S opens during idle, so that is probably your problem
try this, put your hand over the outlet of the bov and see if it idles fine
