peak boost
i'm running stock boost with a TBE and without a MBC.. and the boost gauge reads 22psi...
is the car really running 22psi or its just because of the exhaust giving me the wrong reading?
i'll get a MBC too.. just debating on which one...
Exhaust doesn't give you a wrong reading. What happens is there is reduced backpressure, so the stock boost rises. Sometimes, it rises enough to cause fuel cut.
ya i got a full turbo back without a boost control right now my greddy profec is halfway hooked up so i will finish it this weekend that also showed i had a peak boost of 24.9 psi i only have it mounted and power and vacuum line run to it but my gauge is an SPI which is now the DEFI brand
Originally Posted by wicked-won
OK according to my boost gauge my peak boost is goin all the way up to 25lbs on the stock solenoid valve has anyone else seen readings like this
Um, running ridiculously high boost for no reason doesn't mean your Evo is strong. It means you will soon blow your engine or your boost gauge is off. If Al custom tuned you and saw the boost at 25psi, he would have told you to turn it down. Adding an MBC would not make it boost 30psi, and there's no way it only tapers to 28psi. Pretty much nothing you said made sense, outlaws. This guy isn't talking about a stock Evo randomly overboosting...this is after adding a TBE, which we've already explained why the boost raises.
Oh! There is a alcohol kits intalled during the tune as well! for got to mention. sorry
