peak boost
Old Apr 23, 2006 | 12:12 AM
nj1266's Avatar
Originally Posted by outlaws69
Dude! The same thing happened to me when I bought my car. hook up the boost gauge and the car was reading 25psi with nothing else done to the car at all. Checked everything, still reading 25psi. While Dynoflash tune my car, with all Al's computers hook up, it was reading the same thing 25psi stock. Installed a MBC during the tune, my car is now boosting 30psi taping 28psi with a TBE and cams. Sometimes my car boost so hard my Defi gauges blank out, it happens. Maybe you got a strong EVO like I did.
Turn your MBC down. Your boosting too high. That is too high to run on pump gas. The Dynoflash removed your fuel/boost cut and now, for some reason, you are at 28 psi. IMO, you should not boost above 22-23 psi on pump gas. Save your engine. It is not worth it to run that high boost.
Old Apr 23, 2006 | 12:14 AM
outlaws69's Avatar
I forgot to mention I have a alcohol kit installed. but the 25psi that I was running was all stock.
Old Apr 23, 2006 | 08:43 AM
Warrtalon's Avatar
You forgot to mention....jeez, come on.
25psi "all stock" is very dangerous and I've never heard of it on any other Evo. You're lucky it didn't melt a piston.
motocooney
Jul 21, 2011 08:37 PM
yancy21usa
Mar 28, 2011 01:50 PM
Turbo-Evo2346
May 11, 2006 12:19 PM
crazynyevo
Dec 13, 2005 09:47 PM
