boost leak almost fixed..
Old May 11, 2006 | 11:02 AM
Turbo-Evo2346's Avatar
So for a while my car would only peak at 17 through out the rpm range. I just installed the MR JDM BOV and now it peaks at 19 PSI. So im thinking that it might be another leak somewhere also.
Old May 11, 2006 | 11:12 AM
Aux.'s Avatar
Does it peak at 19 or does it drop to 19 ? Also do you have a MBC ? If you do when it was installed did the lines get changed out with them or did you use the stock lines ?
Old May 11, 2006 | 11:36 AM
it just peaks at 19 PSI and i do have a MBC but it wont go any higher. I have messed around witht he MBC to see if thats the problem but im almost positive now that its another boost leak.
Old May 11, 2006 | 11:44 AM
WrX Kila's Avatar
stock turbo?
Old May 11, 2006 | 12:14 PM
lilnaz's Avatar
What kind of MBC do you have? Is there a stiffer spring you can put into it? If so try that
Old May 11, 2006 | 12:19 PM
Aux.'s Avatar
Put in the harder spring. If you have a Forge Unos alot of times the spring vary a little. Try the harder spring and turn it way down and adjust it as you go.
Jp7
Jul 3, 2017 10:05 AM
gentlyharsh
15
Oct 18, 2009 08:21 AM
worksevo89
18
Sep 7, 2008 03:56 PM
REDEVO1113
Nov 19, 2005 11:35 PM
Bobby12many
13
Aug 30, 2004 05:31 AM
