Need some help asap!!!
Old Feb 23, 2006 | 10:50 PM
evoracer32's Avatar
i just installed my ams turbo kit and on the tial wastegate their are 2 places to hook up lines, wuts the bottom place for, i no the top is for the boost line but wut is the other place for
Old Feb 23, 2006 | 10:59 PM
WHTEVO's Avatar
If you are using a manual boost controller you use the one on the side. If you are running a electronic boost controller you will use both of them. Good luck.
Old Feb 24, 2006 | 12:58 AM
evoracer32's Avatar
thanks for the quick reply so wut do u do with the top opening just leave it? And also when u install the turbo do u need to prim it with oil or anything, im just asking cause after i shut my car off u can here the turbo spinning very loudly, idk if thats normal with the ball bearing turbos or not
Old Feb 24, 2006 | 09:13 AM
WHTEVO's Avatar
You just leave it as it is.
As for the turbo, it sounds to me you have already had your car running. So all is well, there is no need to do anything when you start your car. Good luck.
patrick.painter
Jan 21, 2011 02:35 AM
Rice7x
Jun 29, 2007 03:56 PM
evomaster
Oct 20, 2003 07:37 AM
May 4, 2003 08:02 PM
Lancer Engine Tech
12
Apr 25, 2003 10:16 AM
