alky injection version2 smc,,,,NOT SPRAYING NO MORE...HELP?
Old Feb 28, 2006 | 11:01 AM
yesevo's Avatar
Suddenly The Spray Yellow Button Doenst Turn On Whenever I Hit The Boost Or Push Spray Button,,,
It Doenst Spray At All./...but I Could See Faint Yellow Spray L.e.d Light On In The Night Time..
So I Had To Turn The Boost Down To 20psi,,,good Thing I Found Out Before I Hit The Boost To 29psi
Anyone Know What The Problem Would It Be?
I Have Power Going On To Smc Controller Module....
Old Feb 28, 2006 | 12:10 PM
fuzzychi's Avatar
Check your grounds and if possible have someone press the button while you take a look at the pressure gauge. If it isn't going around 100psi then there might be something wrong with the pump. If all else fails, give Steve a ring at SMC, he'll get you fixed up.
Old Feb 28, 2006 | 12:22 PM
kmcconn9's Avatar
/\ agreed, check the ground and the pump...steve will do anything he can to help..
Old Feb 28, 2006 | 04:52 PM
boostedwrx's Avatar
Reason #147 I dont have alky..
Old Feb 28, 2006 | 05:49 PM
use2vtec's Avatar
could just be the light is bad in the controller. Check your pressure gauge and make sure you are seeing 100 psi at the nozzle.
Old Mar 1, 2006 | 05:49 AM
yesevo's Avatar
i dont see no psi at the nozzel and no pumping sound ...
there is power going on at controller module...
anyone know steve's phone #???
thanks
Old Mar 1, 2006 | 05:52 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
turn the max spray dial way down and get to that psi and see if it comes on...... (i think they go pretty low). My box took a crap and thats what happened.
Old Mar 1, 2006 | 06:14 AM
Ultimate CC's Avatar
If you have a failsafe you don't have to worry about that, my snow performance kit has one
Old Mar 2, 2006 | 01:08 PM
yesevo's Avatar
bump for help
Old Mar 2, 2006 | 01:27 PM
Evotech8's Avatar
SMC Enterprises
(270) 522-9376
Sounds like a controller issue?
Take a voltmeter and see if your getting any voltage to the pump.
This would tell you if the controller or pump is bad.
Old Mar 2, 2006 | 01:41 PM
DrBump471's Avatar
Just bought a Wideband for a reason Easy way to verify the kit is in working order regardless of lights. I can't wait for his failsafe option too
Old Mar 2, 2006 | 02:55 PM
DynoFlash's Avatar
Just call Steve at SMC - he is a great guy and fully warrantys all his kits 100%
Old Mar 3, 2006 | 06:16 PM
yesevo's Avatar
i will call him let u know what the problem is,,,
my car feels so slow now...i cant drive like this ,,.haha
Old Mar 4, 2006 | 05:10 PM
Tim@AMSperformance's Avatar
what kind of fail safe does snow performance have? Timing retard, rev limiter, boost cut?
Old Mar 6, 2006 | 09:54 AM
yesevo's Avatar
i just called smc, and he told me that it would be a pump problem...
all i need to do is send it back to the smc, and he will take care of it for free....
very good customer service....!
