Shep Tranny
Shep Tranny
I have an 06 Ix and am having grinding issues to 2nd. Does this tranny solve all those issues, are there daily drivability issues with this tranny. I'm looking for a durable tranny with no daily drivbility issues
thanks
thanks
ShepTrans.com EVO - EVO Trans Upgrade
We take your trans and apply all applicable tsb's and updates as well as modify the oiling system and a few other tricks to make it shift. This trans build is used by the quickest and fastest Evo's around including AMS, AL (dynoflash), Buschur Racing, Curt Brown, Pruven Performance.
EVO Trans Upgrade Includes the Following:
* New 1st gear synchro
* New 2nd gear synchro
* New 1-2 shifting sleeve
* New 3rd gear synchro
* New 4th gear synchro
* New 3-4 shifting sleeve
* New 5th gear synchro
* New 5-R shifting sleeve
* New seals , shims and snap rings
EVO Trans Upgrade Options:
* Cryo/rem add $300
* 4.11 Final drive upgrade add $1100
Price: $800.00 - plus $80 shipping and insurance
This includes new 1st and 2nd gear syncro's plus a new 1-2 shift sleeve. This will probably cure what ails you.
* Cryo/rem add $300
Originally Posted by Kee1pride
what about 6speed evos?
I might take it back to the dealer but the fact that it might happen again or per previous threads (they fix one synchro but another fails) is kind of a pain. Anyways I wouldnt mind having a tranny that I know will prob last. Thats why I wanted poples opinions on Shep trannies.
p.s. no mods just floor mats
sounds like a good idea but wouldn't you consider changing the fluids to be a temp fix since some trannies dont have problems and others do. There has to be an underlying problem mechanically that putting in fluids will only temp fix it.
Originally Posted by bigjhoney
Why dont you try to change the fluids to something like BG or amsoil..? Might solve your problem, solved mine.
. Do you guys think if I put that (BG) synchro fluid in my tranny it will solve my grinding issues.P.S. I got my pedal adjusted by someone else.
