Error Code:P0136
Old Mar 2, 2006 | 09:09 AM
Thugline's Avatar
Error Code:P0136
I am getting a check engine light with this code poping up. I wanted to know if this is what is causing a fuel cut in my motor?
Old Mar 2, 2006 | 10:55 AM
Thugline's Avatar
Can anybody help me out here?
Old Mar 2, 2006 | 11:24 AM
Thugline's Avatar
02 Sensor
Anybody
Old Mar 2, 2006 | 11:32 AM
PoorBoys's Avatar
P0136: Heated Oxygen Sensor circuit Bank 1 Sensor.
Old Mar 2, 2006 | 11:33 AM
KazzEvo8's Avatar
Can't give you advice, but using a search engine I find:
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
Got a test pipe? Bad cat? Bad O2 sensor(s)?
Old Mar 2, 2006 | 04:01 PM
bigfishs's Avatar
No it is not causing any change in a/f, fuel cut as it is the rear o2 sensor. This is for emissions control and nothing else.
1. Do you have a test pipe or highflow cat?
2. Do you have an o2 fix like the mecahnical one or electrical one?
When did the light come on, and did you do any mods to bring it on.
If the answer is no to 1 and 2, I would unscrew the o2 sensor (with a o2 sensor removal tool, and inspect it.
If it is wet, or is really carbonized, it may be ****ed. If you can borrow one from a friend who has an evo, swap the sensors out or buy a new one (!00 bucks). They unhook from under the passenger seat (u have to take it out and peel back the carpet I believe.
If the new o2 sensor works, that was your problem, if not, the search continues.
If you do have a TP or highflow cat, put the stock cat in and see if that cures it.
If you have either a mechanical fix or elec fix, you could try swaping to the other (you can buy the mech fix for 20 bucks, and the elect for 50 bucks.
U need to proivde more infor b4 people can help
Old Mar 3, 2006 | 01:13 AM
Thugline's Avatar
I have a 3''Highflow cat, a 3" Dp, 3'' exhaust, stock inj,stock fuel pump, Egt guage,Dejon tool Mbc (19psi) and a SAFC 2 TUNE (on 91). I have been hitting a "Boost cut @ 5,000" Rpm @ W.O.T. and the boost doesn't spike at all. I had a "missfire" code come on because one of the spark plugs was bad in cylinder #4 and I changed it and my idle is fine now(cause it was lumpy before). Will the "P0136" code effect the way my car will perform and do you guys think that I should put the 720cc's and the Walbro fuel on to eliminate the "boost cut". Also, by installing those parts that I just mention will it eliminate the "boost cut" thats going on in my motor?
Old Mar 3, 2006 | 05:09 AM
bigfishs's Avatar
The P0136 code is not causing boost cut. Like I said, that sensor is only for emissions realted stuff. The front o2 sensor (bank 1 senssor 1 helps with fule trim etc).
You could try to get a flash, if you are getting boost cut. It might help. Not sure why you would see cut at 19 psi though
Old Mar 3, 2006 | 05:19 AM
WrX Kila's Avatar
Where can I get a replacement rear 02 sensor.
Old Mar 3, 2006 | 06:37 AM
bigfishs's Avatar
https://www.mitsubishiparts.com/oe_parts_catalog.html
157 bucks. I saw one for 100 bucks somewhere, can remember where.
Old Mar 3, 2006 | 07:18 AM
bigfishs's Avatar
Summit racing also does them for around 60 bucks, but you gotta phone them to find out which one will do.
KOTT
Sep 17, 2008 08:59 AM
Evo8Emperor
Mar 13, 2008 01:00 AM
chakrawal
Jul 7, 2005 02:22 PM
sillypuddy
Feb 9, 2005 06:31 AM
