WR? what is it
Old Mar 9, 2006 | 02:05 AM
EvoRecordSetter's Avatar
WR? what is it
what is the WR, where do i get it, and how much power are people making?
ive read that it boosts faster than stock, looking for info on it, looking to upgrade my turbo, and spool fast, and make more power! thanks!
Old Mar 9, 2006 | 02:10 AM
Compjoc's Avatar
Forced Performance White Rabbit, Its a modified 16g.
Old Mar 10, 2006 | 05:27 AM
more information would be nice.
price
what is modified
spool up
power capabilities
more general info would be nice
thanks.
Old Mar 10, 2006 | 05:28 AM
forum04pl's Avatar
dont waste your time with it, do a search and you will see why
Old Mar 10, 2006 | 05:34 AM
dadriva's Avatar
price
what is modified
spool up
power capabilities
thanks.
too much for power gained (see line 4)
turbo
stock (ish)
not enough to justify $$$ spent (see line 1)
SEARCH!!!
Good Luck!
Old Mar 10, 2006 | 05:35 AM
Compjoc's Avatar
http://linux.forcedperformance.net/m...e=Lancer_Turbo
Old Mar 10, 2006 | 05:38 AM
4G63>OOOO's Avatar
I made 415whp with it, a lot of people bought into the tuner bashing that went on between Buschur and FP due to some distribution issues, but it's the same exact turbo that Buschur sells now as a 20G-9, albeit with the Evo 8 compressor cover.
Same hotside.
Same cartridge.
Same compressor wheel.
You can get them from FP with the 9 housing, but the only thing that you'll gain is some surge protection. I found that the thing doesn't surge with the 8 cover unless you're asking it to make 28psi and you should also NOT use a stiff DV spring, as this will make the surging worse.
Old Mar 10, 2006 | 05:44 AM
nothere's Avatar
it comes on quick, will run to 23 lbs from start to finish ( that I have seen, I think I have seen posts claiming 25)
I have an aftermarket emc, doubt if the stock solenoid would do the trick.
it is a stock turbo with a different wheel. cost around 1600
I like it, though now there are other choices. Buscher, the IX...
Old Mar 10, 2006 | 05:45 AM
SuperHatch's Avatar
I hate it when people ask this question, but they have to...
If you search for "WR" the search will kick back that the term is too short, meaning this question will come back over and over and over....
Telling this guy to search does nothing for him.
Old Mar 10, 2006 | 05:47 AM
dadriva's Avatar
^^ You are exactly right. In my above post I told them to search and then searched myself. I got the same results.
My mistake.
Old Mar 10, 2006 | 05:48 AM
4G63>OOOO's Avatar
I think you can pick up one of these used for a good price, I'd keep an eye on the for sale forums.
Old Mar 10, 2006 | 07:39 AM
Zeus's Avatar
PF no longer sales the WR to the public... because they are sold through Buschur.
Old Mar 10, 2006 | 07:50 AM
dryad001's Avatar
Mine will be up for sale in a few weeks. In all honesty I have loved every minute that this turbo was on the car. Just the power output is fantastic, and when you add meth into the mix the fun is even greater.
I'll be sad to see it go. If I didn't have the 3065 coming I would have no problems keeping it.
Old Mar 10, 2006 | 02:48 PM
Tpayne84's Avatar
I thought that the spool of it was almost identical to stock...am i wrong??
