Buschur SMC kit question
Old Mar 12, 2006 | 07:54 AM
dryad001's Avatar
Question Buschur SMC kit question
I searched a few threads and found some ideas to try but I havent found a definate answer yet.
I installed the IC tank alky kit yesterday and when I first got power to the system I noticed that the low level light was NOT on (tank empty), but the arm and spray light are lit up. It wasn't spraying while the light was on, but I could hit the test button and the car would drop into the 9.0 afr range ans almost kill, so I know the pump is working.
So I filled the tank with denatured alky got on the road and hit the gas, the afrs did drop a lot, I have now 10% more fuel pulled to bring it back hust to 11.0 for right now.
So back to my original problem, is there an easy fix? Is the float stuck somewhere on the brass rod inside the tank, happened to some other guy but his low light stayed on.
I'll call Steve tomorrow if the problem isn't solved.
Old Mar 12, 2006 | 01:24 PM
use2vtec's Avatar
there have been a few threads on this. I think your problem is your floater is stuck.
