High-energy grounding cable kit
Old Apr 28, 2003 | 06:57 PM
  #31
Darth Vivid's Avatar
we have Lineage grounding kits as well as the Hot Earth. the Lineage kit is made from 4 gauge wire and has crimped then soldered for a solid connection. they retail for $119, we sell them for $99. they smooth out acceleration and add at least 5hp. plus, your power accesories run better under power.
Old Jun 9, 2003 | 04:51 PM
  #32
showard232's Avatar
Just installed mitsu's hypergrounding system ($189.00); did the install myself in about one hour and throttle response is much greater, idle's smoothly and is quicker in transition on freeway. Seat-of-the-pants dyno guesstamates 5-6 hp and similar torque. Good investment now waiting forRMR downpipe and cat-back to arrive.
Old Jun 9, 2003 | 05:16 PM
  #33
makku's Avatar
Originally posted by purecoda
Oxygen-free audio cable is supposed to be an ultra-low resistance cable used for audio system installs. Its a bit more expensive but MUCH higher quality than hardware store wire. It is also often shielded, as to not allow as much noise interference into your audio system.
I can't comment on the quality because I'm not an engineer, but as a chemist, I have to laugh when they talk about "oxygen-free". This is just as bad as when I hear bottled-water companies claiming their water has "more oxygen" than the others.
To me, as long as the cable is thick enough, the quality shouldn't matter too much. I would assume that all problems come from the contact points. As long as there isn't too much surface oxidation, I would say it should work fine. But then again, I'm not an engineer.
Old Jun 9, 2003 | 05:34 PM
  #34
mhj1r's Avatar
So does anyone have the wiring diagram for one of those expensive kits (for a mistsubishi that is)?
Old Jun 9, 2003 | 07:23 PM
  #35
jemm's Avatar
Hi Articfury, what ODBII probe/software are you using to capture this data?
Originally posted by articfury
Here is the screenshot from the same car with the grounding kit installed:
Old Jun 9, 2003 | 07:52 PM
  #36
tpm17's Avatar
I just finished installing my HKS earthing kit and damn I've noticed a difference esspecially in the cars idle. When I would be at a complete stop at a traffic light the cars steering wheel used to shake a lot more than it shakes now that the earthing kit is on. I'm super pleased with the results, and installation was extremely easy concidering the instructions were entirely in Japanese. I improvised.
Old Jun 10, 2003 | 01:51 AM
  #37
articfury's Avatar
jemm-
It is not my setup.
A member at my350z.com did the test. He bought it at http://www.obd-2.com .
I hope that helps.
D
Old Jun 10, 2003 | 08:09 AM
  #38
jemm's Avatar
Thanks dude!
PCW
Future Lancer / Evo Models
56
Feb 23, 2007 05:58 PM
Jimmy242
Jun 16, 2006 02:20 AM
3000ways
23
Mar 9, 2006 01:12 PM
WildOne
Aug 10, 2004 08:16 PM
nonmature
Dec 20, 2003 01:24 AM
