850 on a 35R ???
Old Mar 14, 2006 | 07:59 PM
jmartinez1170's Avatar
850's on a 35R ???
can i run 850's on a 35R yes or no ?
if not ill just upgrade to 1000 or 1600
Old Mar 14, 2006 | 08:01 PM
silverofs's Avatar
yea you can but you will start aproaching 100% duty cycle toward 30 psi though
Talonmotosports's Avatar
How much horse power are you planning to make, or how much boost are you planning on running????????
Old Mar 14, 2006 | 08:04 PM
Widebandphillip's Avatar
based on a 35r at 21 psi maxing out 680's at 7k rpm with a 10.4 afr, you'd need 1000's if you plan to boost about 32 psi.
Old Mar 14, 2006 | 08:06 PM
memo3's Avatar
I would go with 1000s
Old Mar 14, 2006 | 08:10 PM
sleet's Avatar
Depends on how much boost you plan on running, I just plan on going with 1000CC & 37R. The difference between 850CC's and 1000CC's isn't that much.
Old Mar 14, 2006 | 08:12 PM
gsujeff55's Avatar
also depends if you are running meth. if you are running meth, they will be fine.....and even without meth, you can run upwards of 30psi or so without any problems.
Old Mar 15, 2006 | 12:35 AM
fimotorsports's Avatar
sure you can, but depends on how much power you want out of the car. I have a set of 1000 cc injectors fs if your interested.
Old Mar 15, 2006 | 08:24 AM
I would like to keep the power around 520whp i dont want to upgrade to a dual fuel pump setup just yet.
Old Mar 15, 2006 | 09:11 AM
twinscrewed's Avatar
With 880's in my car, 2.3, 35R, EMS,..... they reached 104% duty cycle around 25 psi w/ alky. You probably want to go with 1000's.
Old Mar 15, 2006 | 10:48 AM
sleet's Avatar
How much? Send me a PM if you want?
Old Mar 15, 2006 | 11:10 AM
gsujeff55's Avatar
running what, 8:1 a/f? thats waaay off
Old Mar 15, 2006 | 03:50 PM
I thought so too. But Buschur tuned it and I don't think he'd go and make something like that up.
Old Mar 15, 2006 | 05:28 PM
gsujeff55's Avatar
maybe to sell some injectors?
that just can't be right....according to 2 charts, 880cc injectors reach 100% duty cylce at 641hp. that is WITHOUT methanol. spraying meth replaces about 15% of the fuel with the stock SMC nozzle(according to recent calculations by Mr Ted B.)
how much power did you make twinscrewed?
Old Mar 15, 2006 | 07:45 PM
I doubt that. They sold me the 880's and when it was found that they were at their limit, they offered to exchange them for 1000's. I'm just sharing my experience. Take it fwiw.
