hittn 1.5 to 1.7 some times on IX
Old Mar 16, 2006 | 09:09 PM
eccgangster's Avatar
Ima leave it the way it is. It pulls hard and doesnt have anyproblems with that boost level.
TT street tuned it
Old Mar 16, 2006 | 10:24 PM
Evo_Jay's Avatar
Originally Posted by mikiblueeyes
If you have no boost controller extend actuator arm by 1 turn, this will help with overboost. I would not run over 1.5 bars=21.5 PSI on pump gas 22-22.5PSI tops. 1bar=14.7 for the refference.
Good luck
1 BAR = 14.5, NOT 14.7
Old Mar 16, 2006 | 10:26 PM
Evo_Jay's Avatar
Originally Posted by Karma'sEvo
1.4 to 1.5 bar is stock boost if you pull the restrictor pill out
A stock 05 VIII or 06 IX will boost 1.40-1.45 WITHOUT pulling the restrictor pill out.
Old Mar 17, 2006 | 01:08 AM
Poison's Avatar
I have an 05 IX and my defi shows peak boost at 1.7bar. But this is only boost spike. Dyno shows peak boost is 1.3bar. its dangerously high if consistently boosting at 1.7bar or even spiking to that level. Installed an EVC V bc to regulate the boost. set low boost at 1.3 and high at 1.4. still a little boost spike but peak at 1.5 instead of 1.7. hope this help..
Old Mar 21, 2006 | 11:20 AM
Karma'sEvo's Avatar
Yeah if you are using the reading off the stock gauge maybe.... There is no way that it pushes that with the restictor pill in on a dyno or even a lab quality gauge.. ie... defi.
Old Mar 21, 2006 | 12:11 PM
deadbeatrec's Avatar
1 bar = 14.5psi not 14.7 so 1.5 bar = 21.75psi and 1.7 = 24.65 psi just thought i would clarify that up.
Good luck
Old Mar 21, 2006 | 12:16 PM
KOEvo's Avatar
If it is TT tuned you are probably fine. BUT 1.5 bar is as far as you want to take it on 93 oct. from my knowledge.
Old Mar 21, 2006 | 12:54 PM
Evo_Jay's Avatar
You DON'T NEED to pull out the restrictor to read boost. You only need to take out the pill when you hook up a MBC/EBC or piggyback with boost control.
