hittn 1.5 to 1.7 some times on IX
after my tune and all the mods sometimes when I wot the car it hits between 1.5 to 1.7 then tapers off. It feels great should I be worried? is the boost to high on a stock bottom end?
Originally Posted by thetox
depends on what octane gas your running. if your running 93 or 94 you would probably be OK. anything less might cause a little trouble. not 100% sure tho
93 all the time.
got a fuel pump too walboro 255 I
That's dangerously high boost on 93oct.
I dont claim to have the infamous name on this forum like you do. lol ..
BUT I would disagree.. I have a ix and run 1.5 bar and have no sign of knock.. And I run on 91 AZ pisswater
True 21PSI is ok (1.5), but 25(1.7) is too high, he has to be knocking and pulling timing. Does the car feel like it dies up top? If it does timing is definitely being pulled.
Originally Posted by Karma'sEvo
1.4 to 1.5 bar is stock boost if you pull the restrictor pill out
car feels great...
turbo trix ecutek flash
intake
rsr downpipe
fuel pump
fujusibo exhuast...
**** like that.
If you have no boost controller extend actuator arm by 1 turn, this will help with overboost. I would not run over 1.5 bars=21.5 PSI on pump gas 22-22.5PSI tops. 1bar=14.7 for the refference.
Good luck
Good luck
well at least it is on my IX......
