Exhaust question
Old Apr 5, 2003 | 02:18 PM
Gs4toEvo7's Avatar
Exhaust question
Pardon the the question but as I am still just learning about engines and the evo aftermarket I must ask aside from the obvious whats the difference between a turbo back and a cat back exhaust. Also which one is recomended for the EVO 8 and what are the hp gains with each set up.
Thanks, Mike.
Old Apr 5, 2003 | 03:45 PM
DSM Power's Avatar
Simple, the name implies what each is. turbo back usually means a complete system from the 02 housing, downpipe, cat/test-pipe to the rear muffler. cat back is just from the cat. converter to the rear muffler.
Old Apr 5, 2003 | 08:03 PM
silverEVO8's Avatar
Re: Exhaust question
Thanks, Mike.
As the man says turbo back is from the turbo, cat back is from the cat back. The question is which way to go.... generally, a turbo back system will give you more power. In this case, I think that I'll go with the Ralliart "sports muffler kit". I think it is from the cat back. I think it will make the car run better but I don't know how much better... The main reason I'd go this route is because it comes from Ralliart (Mitsubishi factory designed part)
Old Apr 7, 2003 | 12:46 AM
AustinEvo8's Avatar
Don't forget the down pipe...major gains!
Old Apr 7, 2003 | 09:40 AM
silverEVO8's Avatar
The turbo-back exhaust already contains the down pipe
boostislife
Feb 25, 2016 01:03 PM
Tsane
Jul 13, 2015 06:07 AM
chrisoneil4
Mar 30, 2015 08:01 AM
wowzers
31
Mar 8, 2014 02:33 PM
TurboTom107
20
Feb 20, 2014 07:39 AM
