Power Estimate? Im excited!
Old Mar 18, 2006 | 01:07 PM
EMR8's Avatar
05MR
Ported & Polished Head,
Ported polished & coated header
Ported & polished wastegate,
Coated 10.5 Hot side,
1/2m oversized Supertec Valves & valve job,
Cosworth Head studs and head gasket,
supertec titanium retainers,
supertec dual valve springs,
Supertec Valve seats,
Comp 272's,
Fidanza cam gears,
Ebay O2 coated,
AMS turboback catless w/a wrapped DP,
Walbro 255,
Utec,
Apexi Intake,
Evo9 BOV,
One step colder plugs,
GM Boost silinoid,
Will be tunned by George @ P&L
All the parts are waiting to be installed and the head has already been removed. I pretty excited and wanted to know whatcha guys thought? Will i need a clutch??? Any estimates, i know alot of variables and but i would appreciate any input, thanx!
Old Mar 18, 2006 | 01:15 PM
MikeEvo8's Avatar
336 at the wheels on 92 octane.
Old Mar 18, 2006 | 01:20 PM
EMR8's Avatar
Im sorry, 93octane and 100 unleaded will be the fuels the mapps come from built.
Old Mar 18, 2006 | 01:22 PM
Warrtalon's Avatar
Holy cow. All that only to be used with the stock turbo and just a UTEC as your tuning device? I think you may be disappointed.
Old Mar 18, 2006 | 01:23 PM
mooreboost's Avatar
Ohhh, well in that case...
340.
Old Mar 18, 2006 | 01:24 PM
EMR8's Avatar
Why, larger turbo will happen in the future, but i think think over stock i will NOT be disappointed. Thanx
Old Mar 18, 2006 | 01:54 PM
evokw's Avatar
very nice mods but how much did it cost you??
Old Mar 18, 2006 | 01:58 PM
mikiblueeyes's Avatar
I have same on my car except its buschur head ( not his own tough ) I got 350WHP/348TQ on 23PSI AEM standalone You should get similar number with good tuning.
Old Mar 18, 2006 | 02:08 PM
Warrtalon's Avatar
Well, yeah, it will be fast compared to stock, but I'm saying you'll be disappointed considering how much money you've spent. You can get to that power level with about $2k in basic mods. When you go to the big turbo, you'll reap the rewards of all those nice mods.
Old Mar 18, 2006 | 03:48 PM
EMR8's Avatar
350 huh, cool sounds like fun! I did some work my self and the guys over at P&L hooked me up. I dont know how close to the edge we'll tune it, more interested in track days and road racing. Gona try to keep the EGT's low and a little bit safer AFR. Thats why all that crap is getting coated and wrapped, heat management. I was thinkin about a Koyo but gptta save some money.
Old Mar 18, 2006 | 03:59 PM
You buy Koyo when you see that the stock radiator is insuficient. I yet to see my car been overheated. (also it would depend on outside climate)
Old Mar 18, 2006 | 04:30 PM
EMR8's Avatar
Well on my STI i threw on a Koyo and a thermosthat and i could watch the temp go down while on the highway. I think that even if the stock radiator is sufficient lower temps are alwys beneficial especialy at the track... less heat = more power and more consistant power. Why wait till it becomes in-eficient.
Old Mar 18, 2006 | 04:56 PM
Warrtalon's Avatar
Lower temps in the coolant aren't always better. The ECU provides timing based on the coolant temps. So, whereas you want them not to get high, you definitely don't want them too low either. It's like when your car isn't warmed up fully yet - the ECU retards timing to protect the engine.
Old Mar 18, 2006 | 05:05 PM
EMR8's Avatar
Sure, but at the track i dont think your ecu will ever think its trying to warm up... right. In other words i dont think that in a racing evironment a koyo and thermosthat will ever get cool enough for your afr's to be affected by your ecu. But it will sty cool enough to help prevent pre-det. and thus enabling slightly a leaner air2fuel.and better timming advance. Maybe im wrong though
Old Mar 18, 2006 | 05:43 PM
+1 Also for evos when you run lower temp termostat it is constantly in warm up mode (unless you its superhot outside and you are racing) so for race(stricly) its beneficial but for day 2 day driving it is not. Everyone has to see for themself depending on set goals. (For me I have raced on track for 5-10 minutes and the temp barely got to 90C (Metric Defi Gauge) On the freeway its 85C.
Piece
