Just got AMS flashed
Old Mar 22, 2006 | 12:17 PM
  #31
Warrtalon's Avatar
Originally Posted by newimportowner
The reason is they are installing my cams at that time too. Al did a good tune on my car, not saying anything bad. I like Al, All I can say is that I read every day (although not lately within the last 5 days or so....) about all this bull.... infighting with certain people, vendors, or otherwise (you) and AMS just stays in the background keeping out of the crap and making great cars. That said too, they are in my back yard. No offense warr, but you dont do your sponser credit. *** didnt say anything about vendors just you.
Make sense in that case - just a bummer that you have to pay for a full EcuTek license instead of just modifying the existing flash. Unavoidable in this case, I suppose.
What do you mean I don't do my sponsor credit? Not sure what you're referring to, and I'm not sure what the asterisks mean.
Old Mar 22, 2006 | 12:18 PM
  #32
CFaber's Avatar
Originally Posted by Fireball
I just had my car on Buschur's Dyno with almost the same mods, minus the cams and made 284hp/269tq. Now that is a mustang dyno, so a dynojet equivilant is about 346hp/328tq or maybe a little lower on AMS's dyno.
I can't imagine an un-cammed VIII on pump w/ a flash going to make 340-ish on AMS's dyno
  #33
lexat20's Avatar
Originally Posted by TomsEVO
On AMS's dyno awhile back I hit 313hp and 304tq with a mail in dynoflash and a/f ratio about 10.5:1 from 2500rpm all the way to the end of the pull. The difference in my mods compared to yours...I had an AMS intercooler and LICP, test pipe, AMS intake, and something you have I didnt, the 02 housing and 10.5 hotside. Just to compare numbers. By the way, I'm mikes friend from Damar, we met while you were having the work done there. One thing you might want to check into, dont know how much it affects power but are the helix dp and HKS exhaust a full 3" all the way through? I saw a post awhile back from AL at dynoflash where he measured some exhausts and the HKS I believe was smaller in diameter. Also, im sure the high flow cat is restricting you somewhat.
Sorry off topic...is damar a shipping company in wood dale?
Old Mar 22, 2006 | 12:21 PM
  #34
BigAeVo's Avatar
no da mar is a auto shop
Old Mar 22, 2006 | 12:23 PM
  #35
lexat20's Avatar
oh thx
Old Mar 22, 2006 | 04:41 PM
  #36
nnorris7413's Avatar
Originally Posted by rlazer5000
I was gonna say your power was a little low. My friend made 308 WHP on AMS' Dynojet with fairly similar mods, but he was only tuned with an S-AFC. Oh well, congrats man!
I made 308 hp with basically the same mods as you but without the 10.5, 02 housing, or flash. Granted your torque numbers are way higher because of the flash, but your power does seem a little low.
Old Mar 22, 2006 | 04:43 PM
  #37
Nad1370's Avatar
I think AMS's AWD dynojet reads lower than some dynojets.
Friend of mine was dynoed at 309/312 with close to the same mods..03 turbo,264 hks,BR mas pipe..and ran 111mph in the 1/4 on straight 93oct.
So I think your #'s are good.
Old Mar 22, 2006 | 04:55 PM
  #38
SOUTHSIDEITALIA's Avatar
Originally Posted by midwestmonster
I don't agree. On AMS's dyno with basically same mods and alcohol injection, 25 psi, I hit 357 h.p and tq. Isn't alcohol good for about 30-40 horse power. You might be about right where you're supposed to be.
I can say this, Martin DEFINATELY knows what he is doing. It is not the tune!
Same here, same dyno, roughly 300 +/- at 16 psi. Fixed the boost leak, added meth, and picked up the other 50. UTEC tuned.
Old Mar 22, 2006 | 05:06 PM
  #39
Mase's Avatar
for what it is worth, you can not compare two different cars with two different dyno's.
i say this about once a week, a dyno is just a tool, its not magic, yes some people, especially some dyno shops/tuners like to do whatever they can to run some bogus correction factor to make themselves look better.
but at the end of the day, a dyno is just a tool. some work better than others. some are more expensive then others. there are a million factors. whether it be temperature, elevation, humidity, density. etc etc etc. that change dyno readings.
your best indication is run the thing at the track. the traps dont lie
Old Mar 22, 2006 | 05:37 PM
  #40
Warrtalon's Avatar
I just want to be clear on one thing that I wasn't clear on initially. I totally forgot to ask why the car was retuned if it was already tuned. Was this car retuned because it had new mods added? If so, was the previous tune (flash) set for the previous mods or current mods? Just want to be clear on that subject...
Old Mar 22, 2006 | 05:58 PM
  #41
Stop&TurnFreak's Avatar
Dyno, smyno.........check out this link. My car made 314whp on Martin's dyno.
The footage is from Road atlanta, in the Time Trial group, with Open Passing.
https://www.evolutionm.net/forums/sh...d.php?t=190724
See how my measily 314whp stacks up.
Old Mar 22, 2006 | 06:03 PM
  #42
Soon2BEVO's Avatar
That still doesnt really tell us much.
Old Mar 22, 2006 | 06:11 PM
  #43
Download the vid, a picture is worth a thousand words......the sound it worth a thousand more.
Old Mar 22, 2006 | 06:18 PM
  #44
TTP Engineering's Avatar
Who cares, some of us are tired of hearing reasons why he should have stuck with flash tuner A. If he was happy he would have stayed put. It seems like you try and pry every piece of info so you can try to sell upon him another companys flash or defend your sponsor tuner, moreso now since he is banned from evom.
How could you go wrong with Martin at the controls. He tunes everything from his customers cars to his very own which is more that I can say for some.
IMO I think it is time that evolutionm made you pay to play here. If you are going to proxy sell products for your sponsoring vendors I think you should have to become a silver vendor at the least.
Old Mar 22, 2006 | 06:42 PM
  #45
Scheppmo's Avatar
I just had my car on the dyno at AMS 2 weeks ago and got 301whp and 281 tq. Martin said that my numbers were very good considering the mods I have. My car peaks at 21psi.
Just thought I would give you some numbers from the same dyno even though my mods are a little different.
