Just got AMS flashed
AMS's dyno doesn't read any lower then any other Dynojet. They use the SAE correction factor which will lower HP in colder weather. Pruven, Turbotrix, and others will post up higher uncorrected numbers in the winter and higher SAE corrected numbers in the summer. It's all dyno games. The gain can be up to 30whp depending if its uncorrected or corrected.
ok i had a dynoflash before it was through the mail not custom and it wasn't for the mods i have now, the reason i got a flash was because i added the cams/hotside/o2 housing. I am very satisfied with how the car feels, like someone said on this thread a dyno is just a tool i agree, there are people on this board with numbers way up there with similiar mods and im just like woah mine seem low compared to theirs what i should be doing is comparing it to others that dyno at AMS and my numbers may be lower since i have a HFC and a HKS tapering exhaust i doubt there are any boost leaks since my gauge shows boost holding steady and no sounds of boost leak. All ill do now is go to the track and see what i trap at, trap speeds dont vary like dynos do
You got it, BigAeVo! The HFC and smaller ID exhaust aren't helping, plus you probably posted SAE figures. The numbers _seem_ low, but the track will tell the tale. Thanks for clearing up the previous flash details. It was just a mail-in flash and wasn't designed for those 3 recent mods (very good mods, btw).
I do also agree that you should slap in some NGK BPR7ES gapped to .026...
Make sense in that case - just a bummer that you have to pay for a full EcuTek license instead of just modifying the existing flash. Unavoidable in this case, I suppose.
What do you mean I don't do my sponsor credit? Not sure what you're referring to, and I'm not sure what the asterisks mean.
Originally Posted by TTP Engineering
Who cares, some of us are tired of hearing reasons why he should have stuck with flash tuner A. If he was happy he would have stayed put. It seems like you try and pry every piece of info so you can try to sell upon him another companys flash or defend your sponsor tuner, moreso now since he is banned from evom.
How could you go wrong with Martin at the controls. He tunes everything from his customers cars to his very own which is more that I can say for some.
IMO I think it is time that evolutionm made you pay to play here. If you are going to proxy sell products for your sponsoring vendors I think you should have to become a silver vendor at the least.
Originally Posted by CFaber
I can't imagine an un-cammed VIII on pump w/ a flash going to make 340-ish on AMS's dyno
I thought that the dyno was a waste of time, unless you do it for what was stated above. Other than that, go to the track and run your car out to see what you can get as a MPH. Your car may have pulled a WEAK HP number as said by others, but sometimes you'll find that your car pulls the 120mph trap (and it made 307HP on the dyno) while the other car that pulled 330HP ran a 112mph. So in this case, would you even care that car X made more power on the dyno, but couldn't pull the same trap speed yours did with a lower number. I don't think you'd care much at all, and probably feel good that your car pulled what it did.
Dyno's are good tools and nothing more.
Now go have fun with your car and run it down the 1/4 mile!
Originally Posted by TomsEVO
Just to give an idea how the dyno might relate to others, I dyno'd 313hp 304tq at AMS and then soon after at the track trapped a 113.
