Cosworth Cams
Old Jun 11, 2006 | 04:09 AM
  #31
Ted B's Avatar
The Cossie M2s give a 110 deg LSA, like the HKS cams. However, the LCs for the Cossie cams show that if installed straight up, the Cossies are like HKS cams installed at +1.5 Int / +1.5 Exh. So, if one wanted to run the equivalent of HKS 280s at +2/0, he'd install the Cossie cams at +0.5 / -1.5. If he wanted to run the Cossies at the equivalent of HKS at -3/-1 (more top end), he'd set the Cossies at -4.5/-2.5.
The nice graph you pointed to at norcalevo.net shows what one gets with the HKS 272s, when set to +1/-1, which is a setting that I always recommend for the HKS 272s for best all-around street performance. In that graph, the longer valve timing of the HKS 272s is what gives the broader hp/tq bands vs. the factory cams. Where cam timing is concerned, the tighter LSA of the +1/-1 setting he used for the HKS 272s vs. the factory cams at 0/0 (106 deg vs. 110) is why the larger HKS cams spooled ~250rpm quicker than the factory cams.
More hp, more tq, larger power bands and faster spool. It's definitely like having your cake and eating it too.
Old Jun 11, 2006 | 08:20 AM
  #32
evo_007's Avatar
Ted,
Would the effect be close for HKS 264intake/272exhaust set at +1/-1 despite the difference in the effective duration of 8deg between 264's and 272's?
Old Jun 11, 2006 | 08:40 AM
  #33
Ted B's Avatar
Yes, but advancing the shorter duration 264 intake cam is going to give up more on the top end.
Old Jun 11, 2006 | 03:01 PM
  #34
trinydex's Avatar
yes YES, so how can you get that same type of setup with the cossies?
cuz i guess i asked the wrong question... i was wrong to assume that the cossies were more like the 280s when i'm not really sure WHICH cam they're more similar to.
Old Jun 12, 2006 | 01:41 AM
  #35
Ted B's Avatar
If it were up to me, I would probably (at least initially) set the Cossies to the equivalent of the HKS 272s at +1/-1. For the Cossies, this would be a setting of -0.5/-2.5.
Old Jul 25, 2010 | 06:50 AM
  #36
rommel6.5tme's Avatar
Im confussed, I currently have BC 280; Fp Red; 1000 cc injectors; power fc ecu; big intercooler; are the m2 for me???
Old Jul 25, 2010 | 09:18 AM
  #37
tunechi's Avatar
Do research on cas you do realize how old this thread is right?
Old Jul 31, 2010 | 07:53 PM
  #38
bk76's Avatar
hi i have a set of 272 cosworth cams in my 7 and without dialling them in they made 310 hp at the wheels.
i get them dialed in this week and was told by my employer my 7 will be at 350 hp, i rate them alot a cood lumpy cam and heaps of power through all gear changes.
JKav
24
Feb 4, 2017 04:14 PM
Rossi_24
Mar 9, 2016 06:43 AM
Migsubishi
Oct 6, 2012 07:46 AM
izabran
11
Jan 8, 2011 10:52 PM
SBR Inc2
Sep 11, 2009 06:19 AM
