Throttle Body Spacer??
Old Mar 26, 2006 | 05:25 AM
EvoTech's Avatar
Anyone tried this yet? Looks interesting. Found it over at Cobb Tuning.http://www.rallysportdirect.com/shop...99f3dda0f54164
Old Mar 26, 2006 | 05:44 AM
hotrod2448's Avatar
I can't see that really doing much in the way of increasing plenum volume. It might be nice for extra vacuum ports but, I don't see it making any measurable amount of power.
It is easy "bold on horsepower" though as the website says. That's one step above "bolt on hp" and one below "hard on power".LOL
Why do I see these things becoming the next grounding kits? The aftermarket sees the spacers that skunk made for the VQ in the Z which probably works given that cars intake manifold design and figures "here's one more thing we can sell" then makes them for everything.
But, I could be wrong.
Old Mar 26, 2006 | 07:17 AM
Zeus's Avatar
Old school V8 modding there. Hey, I really like the vac ports though...
Old Mar 26, 2006 | 01:59 PM
superz's Avatar
Thats insane On a turbocharged engine a spacer like that will do dik. Imagine adding an inch to your intercooler piping before the throttlebody, will that improve anything? Nope. This mod is worth something if it were a NA car were a longer throttle air entry would produce higher air velocity.
Old Mar 26, 2006 | 03:04 PM
Zeus's Avatar
That's the other way to put it if I was not clear
Old Mar 26, 2006 | 04:22 PM
hotrod2448's Avatar
I might could see it being worth something if it was a spacer that fit between the head and the manifold effectively giving you longer runners, moving the injectors a bit further way helping the mixture and, maybe controlling heat soak if it were a phenolic material.
Old Mar 26, 2006 | 05:39 PM
vwjeff's Avatar
Old Mar 26, 2006 | 05:58 PM
bbbwrx's Avatar
That is not a accurate analogy
This goes between the throttle body and the intake manifold. Adding to the intercooler piping is before the throttle body.
Agreed it will not give you a ton of power but it will not decrease throttle response like longer I/C piping.
Old Mar 27, 2006 | 10:21 AM
RallySport Direct's Avatar
Silver Sponsor
Sorry for the typo on our site. It shows we vendors are human Already fixed it
Also this part will not give great power. But there are some uses for it.
People that have upgraded to a Mangus or other sheetmetal intake manifold normally lose all the Vacuum ports that are on the stock manifold and either have to weld them on or having one hose T fitted 40 times This give the option to have these ports easily.
Also a increase in plenum volume not matter how small is still a increase.
Ben
Old Mar 27, 2006 | 10:36 AM
C6C6CH3vo's Avatar
If it were a little thicker, it would be a nice place to mount a methanol nozzle or two.
Old Aug 30, 2007 | 07:51 AM
honki24's Avatar
Working on cading up something like that right now. Who would be interested? My guess on the price might be... $80 a piece?
Old Sep 6, 2011 | 10:49 PM
ryukinevo's Avatar
Anyone have any luck with this throttle body spacer?
http://www.obxracingsports.com/products.php?pk=1501
Will it fit with an AMS short route UICP?
Old Sep 6, 2011 | 11:10 PM
andred's Avatar
i bought one for my jeep and all it does is make a whistling noise at about 1/4 throttle but no noticeable gains
Old Sep 6, 2011 | 11:35 PM
project_skyline's Avatar
They do absolutely nothing.
Old Sep 7, 2011 | 07:27 AM
ryukinevo's Avatar
The main reason I wanted this is for a clean way to install vacuum lines beside a vacuum block.
But, my concern with using this spacer is my AMS UICP might not fit?
Any thoughts guys?
