Tales of my EBAY O2 housing
Old Mar 29, 2006 | 06:31 AM
  #31
fsugatorbait's Avatar
I was working with the o2 housing last night and there is a lot of material that can be taken out. I was using a Dremel and ball grinder bit and got rid of the lip where it meets with the other pipe and took a good amount out from the center section. Ill be installing it this weekend and have an appt with TurboTrix on monday for a retune. Ill report back about if there is any boost creep.
Old Mar 29, 2006 | 06:46 AM
  #32
anjapower's Avatar
pics? awaiting results anxiously
Old Mar 29, 2006 | 06:54 AM
  #33
TURBevO8's Avatar
eve-slow: I sent a PM to the wrong person on here yesterday after the first PM I sent you. You need to clear your PMs too because you are all full. Anyway, I will buy your jet-coated O2 housing if you still have it and you get my messages. I did manage to get one through with my work email so hopefully you get that and respond. If not, I will check my PMs throughout the day. Thanks, and sorry for the confusion guys.
Old Mar 29, 2006 | 07:10 AM
  #34
honda-guy's Avatar
Originally Posted by DaWorstPlaya
But what baffles me is the fact that the wastegate flapper door is used to control boost. When shut it allows the boost to rise when open it allows the boost to lower or maintain its level depending on how much it is opened. And if you are getting boost creep in the upper RPMs your wastegate flapper at that point should be completely open trying to lower the boost levels. So turning down the boost opening the flapper door even more shouldn't solve boost creep, unless the flapper wasn't fully open in the higher RPMs do begin with. Someone correct me if I am wrong.
Thanks ...
boost creep is not only caused by the wastegate port being too small. it can also be caused down stream from the wastegate port if the port from the wastegate to the downpipe is too small. in that case, you can port the wastgate port all you want but you're still going get boost creep. that's why people port the 02 housing and not the wastgate port on the turbo.
Old Mar 29, 2006 | 07:31 AM
  #35
Silencer's Avatar
Question: I noticed the ebay O2 housing splits the exhaust gases whereas the Works new cast O2 housing doesn't. Meaning the split area on the Works O2 is removed or not cast in to the housing. Works claims to get rid of any boost creep and I can understand why when you have an additional path for the waste gate exhaust to escape to. A blended effect. My question is, the Works O2 housing is supposed to increase flow (ultimately gain hp/tq), how is that possible without a smooth transition of exhaust flow? There is now a barrier to overcome before the exhaust seperates in to the two paths. The Ebay housing keeps this seperation for a more precise flow out of the gate and combines them later. Or is the expected increase of hp/tq come from the larger volume of the Works housing. Not too much data on the Works O2 housing except that people who have bought it say that it increases hp/tq according to their butt dyno. Good discussion/comparison.
Dave
Old Mar 29, 2006 | 07:36 AM
  #36
stevEVO8's Avatar
+1,
Boostcreep happens when the Exhaust gas iswnt relieved fast enough to slow the turbo, anything preventing this flow will cause creep.
Old Mar 29, 2006 | 01:03 PM
  #37
DaWorstPlaya's Avatar
Dave
In theory the split O2 housing causes less turblence upstream and lets the exhaust gas combine downstream which is supposed to net more power but ultimately is is the volume/size of the O2 housing the dictates how much additional power is generated as there is less back pressure. If the sizes are the same between the split and none split, the split should be slightly more efficient generating a 2-3 more HP ... hardly worth writing home about ...
Old Mar 29, 2006 | 01:27 PM
  #38
Jeff_Jeske's Avatar
Considering how small the wastegate flapper is I really dont think there is much of a need to port the wastegate exit hole bigger than 1.5".
Old Mar 29, 2006 | 01:34 PM
  #39
Silencer's Avatar
In theory, can you have the reverse effect by too much volume in the housing?
Old Mar 29, 2006 | 01:38 PM
  #40
Jeff_Jeske's Avatar
I wouldnt say too much volume but the way the WG stream enters the exhaust stream could make a difference. I left mine stock and I am loving it. No problem with creep or spikes.
Old Mar 29, 2006 | 01:44 PM
  #41
By reverse effect do you mean less or more turbulence? I would assume the larger the volume of the housing the less the HP robbing effect turbulence would have ...
Old Mar 29, 2006 | 02:45 PM
  #42
Jeff_Jeske's Avatar
Don't forget hot gas benefits from velocity.
Old Mar 29, 2006 | 02:48 PM
  #43
Don forget that when hot pressurized gas is allowed to rapidly expand it cools down very quickly.
Old Mar 29, 2006 | 03:01 PM
  #44
Jeff_Jeske's Avatar
Which is a bad thing.
4g63kid
26
Feb 15, 2012 04:58 PM
ries
Aug 22, 2006 06:07 AM
Jeff_Jeske
19
Aug 9, 2006 09:26 PM
NIevo
Apr 16, 2006 10:09 PM
talon2evo
Mar 2, 2006 08:45 PM
