MBC is being a douche bag
Originally Posted by Turbo-Evo2346
The MBC has the ability to lower the boost but not increase it....does that make any sense to anyone because im baffled.
Make sure you connect the MBC the correct way, I had mistakenly installed MBC the wrong way many times, there are soo many MBC in the market that it is crazy, per instance the TurboXS incresases boost by rotating the screw the opposite direction of everyone elses. Bottom line, just double check the lines.
Carlos
Originally Posted by dan628
Make sure you use the turbo outlet as the source and NOT the t-method to the BOV like many people mistakably do.
You can run it that way, but switch to the turbo outlet for the source and you'll see what I mean.. I stupidly installed mine the first time using the BOV method, and had a lot of weird problems (suring, bucking, etc.) , now when I use the turbo as the source it works perfect...
Originally Posted by Soon2BEVO
You can use either, it doesnt matter. Ive been using the BOV line as source with my Hallman MBC for 40k miles and it works fine. Many many other people do as well, without problems.
Since you are trying to control boost pressure at the manifold, the manifold is your best reference point for the Hallman and controlling boost. Taking your source of boost pressure at the turbo is going to cause a greater variablility in your control. For instance, air flow increases as hp increases, and dp increases accordingly. As the dp between the turbo and the manifold is in a constant state of flux, so will your boost control at the manifold. Manifold pressure and turbo pressure will not be the same nor will the dp between the two, and if you try to control off turbo pressure, you WILL see more boost taper and variablility than if you tap the manifold (or the line to the BOV for instance).
This just goes to show, you can't always believe what you read on the internet.... Even hallman's instructions say to use the turbo as the source. I get very little taper if any at all.. I hold 20 PSI damn near all the way to redline... I get full boost between 3000 and 3500 rpm. I guess every car reacts differently.
This is straight off hallman's website, scroll all the way down and you see how they say to install it, right off the turbo outlet!
http://www.hallmanboostcontroller.com/howto.html
I dont get this heavy spring stuff. I purchased my Hallman right off boostcontrollers.com and installed it right there. I never had to touch springs?
Originally Posted by taenaive
Hallman pro RX comes with 2 springs, and you have to put the heavy spring in. one installed on Pro RX is the light spring and it is for hondas. Regular Hallman comes with the Heavy springs but sometimes they ship out with light spring for honda like cars. and the light spring only holds till 14~15 psi max.
