First Oil Change?
Old Apr 7, 2003 | 01:30 PM
ink124's Avatar
First Oil Change?
Okay, I'm trying to find out what the general consensus is as to when to do your first oil change on the EVO VIII? I've heard people say that the first should be done at around 1000 miles. On the other hand, I've heard people say that you should really let your engine break in and not do an oil change until it's time, ie 3750 or 5000 miles.
Thanks in advance!
Old Apr 7, 2003 | 01:44 PM
mark2002lancer's Avatar
The first oil change should be don inbetween 500 and a 1000 miles becouse you should get what ever might be in the motor out and about 500 miles is good amount of time to get the stragelers from the factory
Old Apr 7, 2003 | 02:49 PM
iodine23's Avatar
If the oil really needed to be changed 500 miles in then Mitsubishi would've written that in the manual. That said, I don't think it will hurt the car to change the oil earlier either. Some cars supposedly ship with an additive to aid in break-in, requiring a very long time until the first oil change (S2000 at like 7500 miles). But since Mitsubishi doesn't mention anything like that, changing the oil early shouldn't be a problem.
Old Apr 7, 2003 | 03:13 PM
stvbreal's Avatar
1700 miles on same oil. I talked to the Ralliart techa nd he said it's utter nonsense to change the oil at 500 or even 1000. He said once you take the car off the lot, dont bring it back untill it has 5000 miles on it, or if something were to break of course. I kinda looked at him like he was kidding, but he wasn't. Just chcek the level.
Old Apr 7, 2003 | 10:33 PM
silverEVO8's Avatar
Re: First Oil Change?
Thanks in advance!
You have it in the manual, if you drive it so if falls under severe use, go 3750 miles. Otherwise 5000 miles just like the book says. I'm always amazed at folks who believe that the manufacturer would suggest a longer interval than the car requires, specially the Mitsu dealers that have been so **** about telling people that they'll void the warranty if they even look at the car the wrong way Heck, if anything, the service intervals are probably in the cautious and conservative side. I plan to check the oil and take it in a the suggested intervals.....
Old Apr 8, 2003 | 05:32 PM
limey's Avatar
My oil was filthy at 600 miles.....I have now done 2000 miles after the oil change I did at the end of break in.....and the oil is still a lot cleaner than the first oil from the factory....having done nearly three times the miles.....I can sleep at night knowing my turbo life is not being jeopordized by crud running around my brand new impeller shaft
Old Jul 11, 2003 | 07:10 PM
Capt_Crunch's Avatar
I have 750 miles on mine. I noticed the oil level is 1/4 inch above the top mark. The owners manual indicates "Overfilling crankcase will cause oil areration and loss of oil pressure...." Should I be concerned? Should I drain some? I have heard other this is so for other owners and Mitsu adds extra oil at the factory? Thoughts? BTW the oil looks light, clean, and in good condition.
Old Jul 12, 2003 | 09:05 AM
Good morning and **** it is a hot morning here in Phoenix. I just drained my oil to exactly the top notch. 1/8 quart or 150ml came out. I do not think that will be a big deal.
Old Jul 13, 2003 | 06:26 AM
Sunder's Avatar
Originally posted by iodine23
ISome cars supposedly ship with an additive to aid in break-in, requiring a very long time until the first oil change (S2000 at like 7500 miles).
Actually, S2000 first oil change is 1000km. It's 10,000km before switching to SYNTHETIC, which is probably what you're thinking about.
Only the 0-1000km has the special additive in it though. 1001-10,000km is just regular mineral oil.
Old Jul 19, 2003 | 08:55 PM
noworld's Avatar
Re: Re: First Oil Change?
Originally posted by silverEVO8
...specially the Mitsu dealers that have been so **** about telling people that they'll void the warranty if they even look at the car the wrong way
the service department at my local dealership said that changing the oil myself voids the warranty. Are they blowing smoke to get money out of me, or is there bite to this bark? I failed to discern that language in my warranty manual - in fact, i recall wording pronouncing maintanence to be the responsibility of the owner. Whats the deal here?
Old Jul 19, 2003 | 09:19 PM
the evo wins's Avatar
I just took my evo to get an oil change at the dealer today and it's my first one...i have about 2500 miles on it...should i have done one earlier?
Old Jul 19, 2003 | 09:27 PM
kidnice's Avatar
Re: Re: Re: First Oil Change?
Do a search for "oil change"
Old Jul 20, 2003 | 07:26 AM
imnobody's Avatar
the book schedual sound right to me. idunno about the techs sometimes either nor the sales guys. but when id doubt go to the book . i dont think they will ever shoot you down for wollowing the book
Old Jul 20, 2003 | 03:01 PM
timzcat's Avatar
You do not need to change the oil until the first scheduled maintenance. But I would do that at 3750 or whatever it says.
It is the oil filters job to trap the particles that may be in the oil from break in and the factory. Plus it is not like the build these things in the garage, they have clean areas where the build motors and you won't find much contamination from the factory. Personally I will change at 3000 but I don't drive a lot so that is about 3 month mark for me.
Old Jul 20, 2003 | 03:07 PM
SilverEvo8owner's Avatar
i changed mine at 3200
