Exedy Twin Disk HD Install Question
Old Apr 6, 2006 | 03:30 PM
itzwolf's Avatar
Exclamation Exedy Twin Disk HD Install Question
The directions really suck so I have a question, when installing the clutch do you disaessemble the clutch by removing the allen bolts on the pressure plate or the normal bolts that are on the back of the clutch? Directions make important note not to loose bolt B, and only loosen bolt A, well which is which?
Old Apr 7, 2006 | 08:19 AM
CBRD's Avatar
well if you remove the bolts from the back of the new flywheel holding the clutch assembly together, when you bolt up the flywheel, you wont have access to those bolts again.
the allen head bolts need to be removed... I believe they are 10mm allens, and the torque spec on them i believe is also 23 ft- lbs... and flywheels is 98.3 for the 17mm's and make sure you use a 6 point, i have seen people stripping them using 12 points.
cheers
cb
asu11
Nov 15, 2016 04:44 PM
MitsuJoe
468
Feb 20, 2016 11:17 AM
atheras
Oct 17, 2013 11:37 AM
Boost3dxEvO
Automotosports - Illinois
Aug 17, 2009 02:51 PM
MisterEVO04
Oct 24, 2006 04:19 AM
