Clutch fork direction??
installed my clutch fork and bolted the trans back up. Is this the correct way for the clutch fork to be or do I need to spin it 180 degrees?
im hoping its correct otherwise the trans is coming back off
It was in there properly, however when I was trying to bolt the tanny back in the, the ring on the t-out bearing kept falling off. So I have to take the tranny off again, once everything was fixed, the fork went back in place.... not a fun evening, but these things happen when you rush installations..
Grease?
Grease?
SQ2Evo
12
Feb 16, 2013 08:43 AM
nhsean69
Mar 11, 2010 06:26 AM
