Clutch fork and TOB questions
Hey guys and gals,
I recently installed my transmission along with a Competition Clutch and OEM flywheel. The comp clutch came with a new TOB and alignment tool. The transmission is installed and I'm buttoning everything back up when I realized that the clutch release fork sits on the far passenger side. I can move it to the middle / towards the driver side but I have to do it manually. I am worried that the used clutch release fork springs are weak and won't re-center the fork on their own. I can look up from the bottom service window and see that the TOB appears to still be attached and it does move through a range but I don't see how the clutch will be released if the fork doesn't move back to center on its own. Any help would be greatly appreciated.
Okay, but are the springs used on the clutch release fork supposed to pull the TOB back towards the engine / pressure plate?
I'll have to upload pictures of where my fork sits and see what people think.
I just installed a 5 speed in my MR with a monoloc and i had to you some good force to get it to snap in place then hook up your slave and watch the fork threw the inspection hole while someone pushes down the clutch pedal to make sure it is locked in place
Did you have the throwout arm out of the bellhousing? There's four ways you can install the springs and only one is right.
Clutch Fork sitting to the left side- clutch not engaging
Hey, i know this thread is old but im also having this issue as well, my partner and I replaced the slave cylinder and we have pressure in our system but clutch will not engage, our fork is sitting too far out to the passenger side and will not sit in the middle where it should be.
could you please explain how you fix this in detail so i can go give it a try…
tysm for anyone that can help out with this!
bostonhatcher
Jan 4, 2015 01:22 PM
EvoDan2004
26
May 30, 2013 04:28 PM
ct342
Oct 17, 2011 08:02 AM
halfnhalf83
14
Nov 18, 2009 06:57 AM
