Tranny Reinstall .. TOB Problem ...
Well ... another day gone by still no finished vehicle ... Took the tranny in and out 4 times today ... No matter WHAT we do, we cant get the clutch fork to release ( i think its release)
My best assumption is a problem with the throwout bearing or something.
Clutch fork sits in middle, has roughly 1/4" play to drivers side,
Impossible to push by hand to the pass side
install slave ... bleed... depress clutch pedal ... Slave pushes fork to pass side, it makes a loud click, and does not return....
Is there something special im supposed to be doing when putting the tranny back in?? is the clutch fork supposed to be in a certain position?? Is the lock ring not seating on the TOB .. im lost and stumped and frustrated and ready to take a plasma cutter to the car and part it out!
so the clutch fork is in the middle that sounds about where it should be. When you install the tranny the fork will be on the passenger side and you just push it a little towards the driver and it should pop and hold near middle.
Well She is ALIVE!!! Somehow (idk otherwise id post a writeup) but my buddy Matt was able to pop that ring into place, with a screwdriver THRU the access hole on the bottom of the Tranny!!!!! IDK What he did, but it worked, ive got almost 50mi on it no problems, shifts beautiful, engages amazing ... big thumbs up for not having to drop the tranny ... again!!!
Well, glad you got it to work
ElectricBlueIX
15
Nov 23, 2019 05:08 PM
Z_Lancer_Man
15
Mar 20, 2018 06:00 AM
marcusE
16
Jun 26, 2013 08:15 PM
SQ2Evo
12
Feb 16, 2013 08:43 AM
