where to get a anti surge cover for my 35r.
Old Apr 7, 2006 | 11:26 AM
smg944's Avatar
i have been looking for and anti surge cover for my gt35r now for about 2 weeks. i cant find anyone who has it. only precision carrys the drilled style. i want the double inlet style. anyone know of a good shop that might be able to make or get me one? heres a pic of what i am looking for, its small. thanks in advance.
Attached Thumbnails where to get a anti surge cover for my 35r.-gt35r-anti-surge.bmp
Old Apr 7, 2006 | 11:27 AM
TrinaBabe's Avatar
Any vendor could get an anti-surge cover. Call Buschur, AMS, Precision Turbo, Turbotrix, etc, etc...
Old Apr 7, 2006 | 11:32 AM
smg944's Avatar
i have tried ams and precision with no luck. i will try the others and post back. thanks for the reply.
Old Apr 7, 2006 | 12:02 PM
TrinaBabe's Avatar
I asked AMS about it awhile ago and they could then. Anyone that can sell turbos should be able to get the covers. I think most companies just drill the cover to make it anti-surged. Im not sure who actually makes a true port shrouded cover.
Old Apr 7, 2006 | 12:04 PM
GTVEVO's Avatar
Call ATP Turbo, they can get it to you or atleast point you in the correct direction. They have great customer service.
Old Apr 7, 2006 | 03:16 PM
evolved4g63's Avatar
I had to get mine sent to pte. The backing plates are different between the e and s covers.
Old Apr 7, 2006 | 04:42 PM
NDgsx's Avatar
Forced Performance
Old Apr 7, 2006 | 06:32 PM
spoolint78's Avatar
just curious why you want an anti surge housing?
i hear it hurts spool
Old Apr 7, 2006 | 08:13 PM
GTVEVO's Avatar
You are correct, the back plate has to be changed so you will need the cover and the back plate kit, usually around 35-45 dollars. To change the plate is not very fun, I had to modify a good pair of needle nose plyers to get the clip off becuase I couldn't find the right size tool.
Old Apr 7, 2006 | 09:32 PM
EricJ@AMS's Avatar
How much do these go for? I have one from a bad turbo. Depending on how much the cover is worth, I'd consider parting it out.
Old Apr 7, 2006 | 10:45 PM
PTE also re-balances the assembly.
Old Apr 8, 2006 | 12:47 AM
EvOcHaRgeR's Avatar
I heard that the double inlet anti-surge cover your looking for gives no surging at all but you lose a little on the top end. However, the bulleted style antisurge does the same thing without losing top end. The top 35R kits like AMS, buschur all use the ported S shroud bullet style for a good reason opposed to the double inlet.
Old Apr 8, 2006 | 04:34 AM
94AWDcoupe's Avatar
The cover PTE sells, the one with the multiple holes is a double inlet also. A ported cover should also be termed "map width enhancement grove" At the bottom of the wholes is a grove that feeds the blades. The compressor map is wider which is why the turbo is less likely to surge.
Old Apr 8, 2006 | 04:52 AM
GTVEVO's Avatar
The anti surge covers were going for about 200 bucks new, their is nothing to re-balance becuase the cover has nothing to do with the rotating assembly.
Old Apr 8, 2006 | 06:47 AM
smg944's Avatar
gsnt sent you a pm. also i spoke with ams again and they said they could get me one for $205.
