Is 0 psi possible?
Old Apr 10, 2006 | 11:43 AM
mack4477's Avatar
Is 0 psi possible?
i know most of you guru's on here will think that i'm a moron, and that's fine with me. but in my boredom of driving a truck today, i wondered if it would be possible to turn the boost all the way down to zero, and just run the motor. or would that screw something up? just a curiosity question.
Old Apr 10, 2006 | 11:47 AM
healthynine's Avatar
Its not possible. With the boost turned all the way down, the wastegate will still be running 11 psi.
Old Apr 10, 2006 | 11:48 AM
fromWRXtoEVO's Avatar
I have seen that happens on a few of my turbo cars in the past only when the turbos were completly frozen.
If you have a MBC and turned all the way down you might almost get 0 psi as well. A partially open BOV or partially open wastegate actuator could also prevent you from building any boost at all.
Carlos
Old Apr 10, 2006 | 11:49 AM
Warrtalon's Avatar
Not with the MBC, but you can run 0 boost if you disconnect the wastegate arm, I believe.
If you have a partrially open wastegate you might build absolutely minimum boost but most of the air would escape fast.
I am not here to contradict anyone though, I am not saying is not possible. I am refering to a situation where a opening exist and the turbo can't simply generate boost fast enough.
But I can confirm that 2 frozen turbos on a Stealth TT that I had gave me absolutely 0psi. If a turbo is healthy and unless you have a big big leak you should be able to generate at least minimal boost.
Carlos
Old Apr 10, 2006 | 11:51 AM
bluebanana23's Avatar
Actually, there is an on-off switch for the turbocharger located just behind the hotside. Just kidding, what was typed above is true due to the wastegate.
Old Apr 10, 2006 | 11:54 AM
mack4477's Avatar
nothing frozen or any problems or anything like that. i was honestly just wondering how the 4g63 did by itself without the turbo. may make for some closer races too
Old Apr 10, 2006 | 11:56 AM
well, the car has a 11psi wastegate so unless you modify the wastegate you still will build boost...where in Milwaukee are you?
Old Apr 10, 2006 | 11:57 AM
Warrtalon's Avatar
With 0 boost, the Evo is a dog just like any regular Lancer...probably slower than a Ralliart.
Old Apr 10, 2006 | 12:00 PM
I can tell you exactly how it feels. It feels slower than the non turbo 140HP twin cam 16valves. The 4g63 shines when works with boost, without the turbo the engine revs up very slow and basicly takes forever to go above 5000rpm.
A frozen turbo still on the exhaust manifold is perhaps one of the worst things you can do to your car. The exhaust gases have absolutely no way to go, the tuirbo clogs the exhaust gases.
As I mentioned before, I once bought a Stealth R/T twin turbo with both frozen turbos(lack of oil to the oil supply lines due to poor quality oil and not cooling them down), the car ran approximately a 10 sec 0-60. It was way worst than the Non turbo version. The same theory here, the turbos when frozen are robbing you a lot of power.
Carlos
marksae's Avatar
If you disconnect the wastegate arm, then the exhaust will take the path of least resistance out the exhaust. I'm guessing that not all the exhaust will pass through the wastegate in this situation, so some of it will end up going through the turbo, but probably not enough to build boost.
Old Apr 10, 2006 | 12:02 PM
I absolutely agree. Perhaps slower, the air flow is non existent and the rpm can't just rev fast and high. It is a experienece that everyone should experience, it is very weird. The 4g63 is like a engine that likes to rev high when mate to the turbo, take the turbo away and the engine takes forever to rev.
Carlos
Old Apr 10, 2006 | 12:05 PM
Your explanation is bullseye, I am still inclined to believe that due to the massive air leak through the wastegate there is no enough back pressure to keep flowing and despite having some flow going through the turbo it is simply not strong enough to generate boost.
Carlos
Old Apr 10, 2006 | 12:44 PM
dayf's Avatar
8.8:1 compression with 0 boost, ~3300lbs and AWD? Yeahhh much slower. lol.
black_beauty
Apr 19, 2015 05:16 PM
zelskeet
For Sale - Cars For Sale
Sep 29, 2014 06:11 PM
justin22s
Apr 3, 2014 12:14 PM
MitsuSkot
30
Oct 21, 2004 02:21 PM
Jamievo
13
Aug 23, 2003 11:16 PM
