31 psi oil pressure???
I installed an autometer oil pressure gauge and immediately jumped on the road to go out of state for work.
Only problem is the gauge reads 31 psi while I'm driving/cruising. It reads 10 at idle.
I was cruising at 60mph= 28psi, cruising at 80mph= 31 psi.
I tapped into the head just to the right of the thermostat housing. I removed the bolt using an allen key as described in another thread and this is the result.
Why is the pressure so low?
The pressure is so low because of where you have tapped the sender at. If you had tapped into the oil filter housing it would have read higher.
With that in mind, you should still be reading higher than 0psi at idle...
Originally Posted by EVOONYOASS
Opps, sorry! It goes up to 20 psi when I start the car and settles back down to 10. I didn't mean to say 0 I thought I typed 10.
+1
I have it in the same spot as you. The pressure should never hit zero and while cruising I'm at 25 psi and with a load on the car it reads about 37 psi.
It's not a bad spot for the gauge if you want higher pressure move it to where the filter is.
The guage actually came in handy last week. All the gauges read normal except my EGT (DLI2 took a crap on me and fouled a coil) car was running real rich EGT didn't get above 400 degrees. But all other oil guages and water temp read normal.
I'm using a mechanical gauge so no sender. I used the hose that came with the gauge.
What about 31 psi while driving? Isn't that a little low?
