HKS camp system install
Old Apr 9, 2003 | 02:58 PM
wing240's Avatar
thanks! hei, most of the stuff I can do it on the emanage, and I want to maintain 2 maps, one for high boost and one for low boost, can you help me tune on that??? Lamda value? you mean that the evo 8 has a wide band o2 sensor?? it should have 5 wires right? I am not sure the evo has a wideband sensor or not.. can you clarify that? I have time this weekend... you the man..
Overboost cut, you can do that on emanage right??
hmm looks like my emanage purchase is a good choice
Originally posted by Drivemecrazy
Tomei's spec is
IN : 260 degree 10.7mm (Stock 260, 10mm)
EX : 260 degree 10.2mm (Stock 256, 10mm)
I've finished analysis EVO8's data.
Now I can control following function.
Change Rev limits,
Change Speed limits (JDM only, USDM have no Speed limits),
Remove or Change OverBoost CUT,
Change Target boost (If use BC, no need to change that),
Change Fuel and timming,
Change enrichment value when Acceleration,
Radiator Fan On temp,
Attached image is Stock EVO8's Lamda Value (from DATA)
I've order New EVO8 ECU from MMC dealer.
I will take it tommorow... may be...
Old Apr 9, 2003 | 03:01 PM
TaiwanEvo's Avatar
I am so lost already but i still want to say Wing ur car Is ONE BAD ***!!!
Old Apr 9, 2003 | 03:03 PM
wing240's Avatar
hei K,
do you recommand to get the tomei head gasket? that suppost to lower the compession ratio? how about the valve sping, do I need that for the new cam shaft?? oh.. when is my CAM coming?!?!?!
Tomei's spec is
Change Rev limits,
Old Apr 9, 2003 | 10:03 PM
Obsoleteasian's Avatar
WING420.. What are all the parts to do the guages in a in dash screen unit. Can the screen be any kind of only certain ones... and what are all the parts to do this??. I really like this route.. More clean to me.
Old Apr 9, 2003 | 10:09 PM
stvbreal's Avatar
Excellent question. I also want to take this route.
Old Apr 9, 2003 | 10:15 PM
Coolguy949's Avatar
It can be any screen with a standard composite video in (yellow video cable). The unit by itself measures voltage, RPM, and speed I think. You need the junction box (which is expensive and hard to find) to be able to measure boost and some other pressures. You buy the sensors themselves then they plug into the junction box.
http://www.hksusa.com/categories/?id=1082
Go here for a list of parts.
Old Apr 9, 2003 | 10:27 PM
Coolguy949's Avatar
PS - I have a PDF file of how to install the camp system including the junction box and sensors. PM me if you want it. Please include your email address.
Old Apr 14, 2003 | 01:33 PM
GMat's Avatar
So... What happens when you want to use the radio/cd and the camp system at the same time? Does it work?
Old Apr 15, 2003 | 09:28 AM
master(J)'s Avatar
hi wing240
i have the same camp system on evo8 .what i do need to hook up the air/fuel ratio??thank you
Old Apr 15, 2003 | 11:35 AM
wing240's Avatar
you can't hook up the a/f ratio, I don't even know it's wide band or not.. any according to HKS, they discontinute the A/F parts?!?! don't know why.. they want you to buy the A/F Knock Amp..
Old Apr 20, 2003 | 02:42 AM
mk4killer's Avatar
Hey guys check ebay they have what you are looking for this guy japandy has alot of jdm stuff http://cgi.ebay.com/ebaymotors/ws/eB...tem=2411171280
Lata!
Old Oct 10, 2003 | 04:35 PM
mykrrrr's Avatar
Question
This is my question as well.
I don't like A-pillar mounts and the RMR column one seems to be in the way of the other guages. I like the techy idea of the HKS Camp set up but don't want to give up listening to the radio for my bling bling boost guage.
Old Oct 10, 2003 | 08:59 PM
5StarSuzuki's Avatar
In Timeout
No offense...But your picture taking abilities suck Get better pictures...post them!
Old Oct 10, 2003 | 09:15 PM
Ryanmcd2's Avatar
In Timeout
Re: HKS camp system install
I have too say too much stuff for me. :-)
Originally posted by wing240
Finally have time to take some pictures for MY camp system .. if you like to choose the LCD route for your gauges.. I don't like the a pillar mount or holes in the dash.. IMO
it displays press, egt, oil/water temp, injector cycle etc... very clean install... there is an option for the A/F ratio gauges, but HKS do not offer the harness anymore... don't know why, everytime I ask for part number, they try to sell me the AF knock amp system... what a way to make $$, anyways, I am installing the Lamda system with edge-tech/honda wideband sensor on my HKS downpipe , so it's ok..
presure sensor to junction box, main unit behind glove box, next to ecu, perfect fitment.
under chair panasonic main unit.. use the us lancer harness, the same..
with emanage
HKS suction kit "sounds awesome! recommand it"
bov, no stall problem..
let me know if you need help to install it..
catman78
Dec 30, 2011 12:51 PM
hilhi2005
Aug 14, 2007 06:01 PM
theblue
May 29, 2005 08:44 PM
goingtoblanc
Nov 15, 2004 01:33 AM
blonde
Jul 11, 2004 11:57 AM
