475hp 419 ft lbs @ 26psi GT3076R ***VIDEO***
Originally Posted by joeymia
well he did mod the ATP kit and has a different O2 housing...
Oh, the mods are on the first page for those that missed what this or that was. Holla
Originally Posted by FluxedSpeed
This is all on the stock block? How long do you expect the block to last? See if I did this to my STi...no telling when it would blow lol.
Originally Posted by GTVEVO
The biggest GT3076 (-13 CHRA) is rated at 600hp, are you sure this isn't the GT3040 wheel I believe it is rated at 650 like a GT35R.
Im kiddng, different strokes for different folks.
Originally Posted by QuickEvo
525wheel is about the max that Garret claims "per their website" Which would put it around a 650 (crank HP) turbo.
The estimated power potential posted by Garrett and other turbo suppliers is bhp (crank), not whp. The turbo suppliers calculate this number based upon the choke flow limit of the turbo. When Garrett says, "Ideal for medium displacement engines making up to 525hp" (GT3076R), that means up to 525 crank hp. Turbo suppliers have no way of knowing the drivetrain losses of the vehicle it's going into, and don't pretend to guess for obvious reasons.
And where drivetrain losses are concerned, the greater the power at the wheels, the smaller the drivetrain losses, so assigning an arbitrary percentage doesn't work. Even so, the drivetrain losses of an EVO are hardly a whopping ~24%.
^^^What he said is correct. As far as how much BHP a turbo is capable of producing, ask the builder how many lbs/min its claimed to flow..this is GENERALLY a rough figure as to how much bhp its capable of producing.
I.e. A FP3065/GT35R is rated at a 65lb/min turbo which is capable of roughly 650crank hp. A FP3052 is rated at 52lbs/min = roughly 520bhp.
Welcome to the huge difference between the EJ25 and 4G63t...he's not even to the limits of the stock block yet.
EDIT: Nvm...found what I needed.
