checking spark on an evo
Old Apr 13, 2006 | 09:23 PM
forum04pl's Avatar
so i tried to fire the car finally tonight and no luck. cranks fine, has power, has fuel pressure (i popped off the line to the rail and fuel pissed out) but i think that i have no spark.
i pulled a plug and wire out, not the one with the coil on it, and put the plug in the wire grounded the plug while still being in the wire on the ground on the intake mani, tired to fire fire the car and the plug didnt create a spark.
is this the way to go about checking spark on an evo? if not let me know what else to try. but if it is any suggestions where to start checking?
Old Apr 13, 2006 | 09:25 PM
Sap12687's Avatar
God Speed my son
Old Apr 13, 2006 | 09:28 PM
forum04pl's Avatar
haha... i dont even know what to say to that, but thanks for the help again, ill give you a call this weekend
Old Apr 13, 2006 | 09:51 PM
Evo_Tuner's Avatar
1. Check the fuse/relay for the ignition coil. 2. Check for voltage to the coils while you crank.
Old Apr 13, 2006 | 10:28 PM
forum04pl's Avatar
sounds good ill check that tomorrow, im calling it a night tonight... any other opinions on stuff to check?
Old Apr 13, 2006 | 11:45 PM
sgevotx's Avatar
Usually i'll check the injector pluse width, crank position sensor and cam position sensor first. Fuel pressure means nothing if your injector is not opening. Good luck.
Old Apr 13, 2006 | 11:58 PM
forum04pl's Avatar
how can i go about checking the injector pulse width and the crank position sensor? i know where the sensor is but how can i check it? my cam position sensor is correct i already checked that one.
Old Apr 14, 2006 | 12:15 AM
sgevotx's Avatar
Juest get a test light and poke on one of the injector harness and crank the motor. If the test light is blinking that means there is injector pluse, if the ight is not blinking than check your crank and cam position sensor. One of the injector harness is ground so test both the wire.
