Engine
Old Apr 16, 2006 | 03:42 PM
Z-Ball's Avatar
Engine
i got the service engine soon light after driving the car around without knowing the intercooler piping was loose. i went and got my codes read and its a po234 which is engine overboost condition. its becuase of driving with the upper intercooller piping partially off. so would i be ok to jsut pull the neg off my battery or should i take it to the shop and have them look at it?
Old Apr 16, 2006 | 03:56 PM
alloyic_rs's Avatar
If your IC piping is off then put it back on! Duh..
Reseting your ecu wont fix anything. The check engine light will come back. Fix your piping.
Old Apr 16, 2006 | 03:59 PM
Z-Ball's Avatar
i did fix the piping.. lights still on... po234 because of drving with the piping partially off.. should i reset now that i put it back on or what? that was the question
Old Apr 16, 2006 | 04:04 PM
alloyic_rs's Avatar
If you fixed it then yeah, try resetting the ecu. If the light comes back then get it checked out.
Old Apr 16, 2006 | 04:05 PM
Z-Ball's Avatar
k coo
