where to fill ACD??
Old Apr 17, 2006 | 02:59 PM
E VOL IX's Avatar
where to fill ACD??
I just did a clutch job and i had to remove the line for the acd. Where do i refill the fluid at??
Old Apr 17, 2006 | 03:06 PM
althemean's Avatar
The reservoir for the ACD pump is under the hood on USDM models. I think it is in the trunk on the LH side on JDM models. You will also need to bleed the ACD lines since you removed it and most likely got air in the system.
Old Apr 17, 2006 | 03:17 PM
djskyy's Avatar
it's the closest resevoir to your drivers side headlight...
Old Apr 17, 2006 | 03:22 PM
Danny23's Avatar
btw after driving cars with acd the fluid level will show its at the low point, this is normal, after the car sits for a while it will come back up to full
