Boost!
Old Jul 9, 2003 | 07:39 AM
Drivemecrazy's Avatar
If you need more boost than stock.
You have to change some function on ECU.
Most EVO in CA. use 91 Octane Gas.
and ECU set and control peak boost around 18~20 psi.
but change Overboost contorol fuction on ECU.
You can reach to 22psi or more.
Old Jul 9, 2003 | 07:50 AM
boostedwrx's Avatar
overboost function in the ECU? Im assuming Shiv would have taken care of this... I think because the Xede map I currently have was only tuned in 3rd gear. We never did any 4th gear pulls on the dyno..
Old Jul 10, 2003 | 11:17 AM
EVO-8-Silver's Avatar
Originally posted by boostedwrx
no Im running stage 0.5 which is Turbo-back plus the Xede's boost line which makes boost more stable and raises it to 1.5 bar.
I think in 4th, I might be pushing 1.55 bar or so though... i think thats what my prob is. My map is tuned for 92 octane and I'm running 94, so I know im not knocking...
If its not fuel cut im feeling, then the engine is misfiring at exactly 4k rpm.
How do u like about your stage 0.5 , and thats what I am planning to get too. Let me know. thanks. BTW, do u know when will the vishnu stage 1 will be available? Vince
