View Poll Results: should i keep the restrictor pill in the clutch line?
leave it
14
45.16%
remove it
17
54.84%
Voters: 31. You may not vote on this poll
Putting in exedy twin hd, should i keep the restrictor pill?
I took mine out i get a better feel for the clutch, but also i still have the OEM Clutch but will have the Exedy Twin HD in soon and a clutch line along with it. i'll see what it feels like then and see if i put it back in or not . also i was thinking about boring it out some i have like three of them here so i might try that also.
Originally Posted by itzwolf
Personally I removed mine, and installed a braided clutch line. Engagement/Disengagement is always the same, swift and smooth. I would never run the restrictor again.
I see no reason to leave it in...the restrictor causes more slippage. Although I can't conclusively say the restrictor caused the problem, I burned up my Exedy Twin disc up in 12,000 street driven miles with zero racing/launches. I associate the problem with the restrictor, not the clutch. I have since removed the restrictor and am much happier with the engagement/feel of the clutch.
Those leaving the restrictor in to prevent transmission transmission failures should try other methods. Clutch jobs on EVOs aren't the easiest/cheapest.
