The highest safe boost for evo
Originally Posted by Makos1610
you wanna tune for 22psi so can you explain to me how come i had 21psi stock and 24psi after exhaust and intake but before flash?
He's not on 93octane - he said he's on 100octane, so he needs to get that whole thing straightened out. If he wants to run 100oct 24/7, then he should get tuned specifically for it and can run a 27psi spike if he wants to. I recommend head studs when installing the cams, but after that, he can run that boost all day and have around 400whp/400wtq, imo.
27/28lbs spike is fine. I've done it many times on 100octane with 272 cams and arp head studs. The stock turbo with that quick/high of a spike is definitely something to experience. Just hold on cause if you can break loose it'll happen.
Knguyen228
Jan 3, 2008 01:48 PM
TonyG
Apr 10, 2004 07:24 PM
