JDM E9 RS bolt up to 04 E8?
Old Apr 21, 2006 | 09:07 PM
boomtown's Avatar
Hi
Would the Jap spec E9 RS turbo (ie Ti/Al 10.5) be a straight bolt up to an 04 E8? If not, what modifications would be necessary?
Thanks in advance.
Old Apr 21, 2006 | 09:28 PM
itzwolf's Avatar
Probably oil lines/water lines as the USDM evo 9 requires the lines when switching.... Possibly the lower intercooler setup as well.
Old Apr 22, 2006 | 02:57 AM
trinydex's Avatar
^ that's it. and tuning change as the rs turbo spools much faster.
Old Apr 22, 2006 | 04:44 AM
boomtown's Avatar
Obviously faster than stock with a 10.5. But faster than stock with a 9.8?
Also can you confirm re: LICP? (Im not sure whether you meant that was also required)
Old Apr 22, 2006 | 02:46 PM
trinydex's Avatar
yes much faster... the rs turbo comes with mg comp wheel and ti al turbine wheel. that is more of a reduction in rotational mass than even the tme can provide.
Old Apr 22, 2006 | 03:14 PM
scott88vr6's Avatar
The LICP is a really tight fit with the starter. I just put a nine turbo into my evo 8
evotuner04
11
Aug 27, 2017 03:28 AM
dturner9020
Nov 14, 2015 06:07 AM
DragonDog
Mar 22, 2012 07:32 PM
