Help Diagnose my Idle Problem
Originally Posted by Ludikraut
Clean your throttle body, it might be sticking and not closing all the way.
l8r)
l8r)
Since you changed the throttle body you need to check these two things:
1. Idle screw adjustment (located on throttle body)
2. Make sure the throttle cable has some slack in it and the throttle plate is allowed to "close" at idle.
threw a code today PO507...Idle Control System RPM Higher Than Expected ---- wow that helps
double checked all my vacuum lines and their all hooked up felt around for any tears and didnt feel any- egr was hooked up correctly-- I did however bypass the coolant lines for the throttle body so it could be sticking but ive taken my hand and actually pulled on the lever to make sure its shut!
ahh... I believe your car thinks its forever in warm up mode then. Try hooking the coolant lines back up and see if the idle dips down after the car is warmed up.
thatsMR2u, is your idle high even when the engine is cold? I also have a small issue with my car idling at 1600-1800 rpm but only when the engine is warm/hot. It will idle at 800-1000 rpm (lopey) when cold, and after being driven for a while sometimes the idle will stay around 1700 rpm, but not always.
Just wondering whether I have the same issue and if I should do the same checks as you did...
My car has HKS 272s, HKS intake, hallman mbc, stock bov, walbro 255, and hks ti exhaust with cat delete.
It may be the tune that you need in order to make it run right. I know Al has perfected the idle control with his flashes, so that may be an option.
anja ive tried all durations of AC on and off - the AC on it almost even makes it idle a little better....
Mostro- my problems is the opposite of yours- yours almost sounds like a temp sensor or your thermostat- what are you running diverter valve or vent to atmosphere?
Even tho I havnt thrown a check engine code im thinking the EGR valve is staying stuck open
I guess i have to throw in my old stock one and see this weekend
Originally Posted by matt55
I think that is your best bet right now , for what ever reason it sound like its not closing all the way . btw do you have a S-afc(or some way of loging TPS) if so what is the throttle position % ? 0% ?
