Help Diagnose my Idle Problem
So over the winter I installed a bunch of different mods.
Buschur ported intake manifold and throttle body
nisei intercooler and piping
evo 9 turbo with 9 oil/coolant lines
ebay 02 housing
dc sports exh manifold
280in 272 exh HKS cams w/ upgraded lifters set to -3,-2 on cam gears
installed 780cc injectors but replaced back with stock trying to fix this problem
Now my idle sits at around 1600 and will not drop down or even idle like normal cams - not lopey at all. Ive changed the plugs, cleaned the maf, changed the throttle body angle position sensor and adjusted it in all positions- it is currently all the way to the right at the lowest rpm setting and still sits at 1600 rpms. I still have stock intake in the car, just MR diverter valve. I can not figure out what this high rpm is coming from please help!
ebay 02 housing
another weird thing is ill be driving and when i go into neutral while driving it will go down to 1000rpms and bounce to 1200 and do a cam idle but soon as I come to a stop it goes right back up to 1600 and stays?!
It may be the tune that you need in order to make it run right. I know Al has perfected the idle control with his flashes, so that may be an option.
Originally Posted by Ichiban
Did you check for any vacuum leaks?
i would also say retune. a buddy of mine had his idle like that went to gruppe-s and got it tuned and they played with his cam gear settings and his is a loping 1k rpm.
btw had 280 in. and exh.
my 2 pennys
my 2 pennys
