Front Diff broken?
Old Apr 24, 2006 | 10:18 AM
Fisher22's Avatar
Front Diff broken?
during the past autocross i noticed that when i would be going around a wide sweeping corner and slowly adding in more throttle the car would not smoothly accelerate; instead it would feel kind of like it's hopping - lurching forward in intevals. I remember the car being much smoother last year. Is this symptoms of a broken front diff or is this normal?
Old Apr 24, 2006 | 10:24 AM
TeStUdO's Avatar
Originally Posted by Fisher22
during the past autocross i noticed that when i would be going around a wide sweeping corner and slowly adding in more throttle the car would not smoothly accelerate; instead it would feel kind of like it\'s hopping - lurching forward in intevals. I remember the car being much smoother last year. Is this symptoms of a broken front diff or is this normal?
Was it making any noises? When was the last time you changed all your transaxle fluids?? i.e....tranny,tc, and rear.
Old Apr 24, 2006 | 10:38 AM
Fisher22's Avatar
it wasn't making much noise, and i don't remeber the last time i changed the fluids, there is only 26k on the car
Old Apr 24, 2006 | 11:44 AM
BigBADGSX's Avatar
I had a similar problem with my GSX, until the whole front end locked up and the car will absolutly not go forward. But the car will roll backwards with no problem....i still have yet to take it apart to see what the issue is. but make sure all you change all of your fluids and see how it acts after that.
Old Apr 24, 2006 | 11:48 AM
TeStUdO's Avatar
Originally Posted by BigBADGSX
I had a similar problem with my GSX, until the whole front end locked up and the car will absolutly not go forward. But the car will roll backwards with no problem....i still have yet to take it apart to see what the issue is. make sure all you change all of your fluids and see how it acts after that.
Its called your transfer case bit the big one.
Fisher22,
Drain your transfer case and then go through the fluid with a magnet to see if there are big chunks of metal in it.
Old Apr 24, 2006 | 12:54 PM
Fisher22's Avatar
ok, i'll do that as soon as i make some time...thanks
Old Apr 25, 2006 | 05:13 PM
Fisher22's Avatar
just thought of something else... could it just be my rear lsd from trying to accelerate while on three wheels?
mantella
Dec 1, 2014 07:46 PM
94AWDcoupe
Nov 6, 2014 03:31 PM
slostjoe
Jul 7, 2008 10:52 PM
hawaiian_evo
10
May 7, 2008 03:45 AM
elhalisf
Mar 5, 2007 01:49 PM
